Bolt patterns of various I.H. Engines.
Binderoid
I need a short ( lengthwise) engine for my topsoil machine. The engine sits across the frame under the hopper, right where it would get hit with the loader if it sticks out too far. I need something with a Rockford style clutch. I have a clutch assembly from a 715 combine that could be made to work, but the engine is way too long. Are there any small motors that would accept a bell housing for a C-301?
     With slightly more effort, I could use a manual transmission bell housing if I made my own output shaft and hung a 4 hole bearing block where the transmission bolts up. I have a couple 6.9s, 7.3s and a 304 which would be short enough for my purpose. With the Ford adapter, the obvious choice would be a bell housing for a 460, but what would fit the diesels with the adapter removed?
    Don’t need a lot of hp , currently powered with Ford 192D and this engine doesn’t work at all.
The 7.3 and 6.9 use the same bolt pattern as the MV gas engines, there are some bell housings around to bolt up a 4 or 5 speed tranny. I think either of those engines would be a bit overkill for your application.
You’re absolutely correct about overkill but these engines are available now and I just need this thing to turn while this engine is getting majored. Doesn’t have sleeves so it’s going to take much more time.
Would a 4cyl German diesel fit in place of a d310 from a late 715?
Not quite sure what you’re asking but yes any in-line 4 would fit (well maybe not a4-71) ... I would love to have a German Diesel attached to that  715 bell housing. If I could find one I’d buy that in lieu of majoring the Ford. What model is that 4 cylinder?
I forgot the sizes, don't have one, but they are the 4 cyl version of the d310 and d358. The belhouse adapter on the back of the engine might interchange. I think there was a 3 cylinder version as well. Thx-Ace
Think there were at least two 4 cylinders a D239 and D246. Used in things like the 74 and 84 series utility tractors, the 5000 swather used the 239. Probably a bunch of other applications that are not coming to mind at the moment.
544
