1486 Dt436 Pump timing
SeanP
How do I check my pump timing on a dt436. Bought tractor with issues. Won’t fire without ether, puts out tons of white smoke when I turn it over. It will stay on and run but sounds like it has a fuel knock and pours out white smoke. Running it in the shop with the overhead door open will just about burn your eyes out. I’m wondering if the pump is off 180 degrees. Thx
pointer on pump hub lines up when engine is at 18*. It sounds like it is 180 out, so bring it up in time, take the 3 pump gear bolts out and turn the pump 1 round, 3 clicks with a 7/8 socket on a small breaker bar. Put 3 gear bolts back in aligning the timing line to the pointer, ensuring engine is still at 18 before TDC. It should start, but may take some ether if its been flooded with fuel from being out of time.
