Dt-361 injection pump
My uncle had some issues with the injection pump on his TD15 dozer with a DT-361 engine, after sending the pump off to get rebuilt and receiving it back we noticed the pump shop sent white plastic sealing washers for the banjo bolts, the original ones were metal or aluminum. I’m not sure which to use as I’ve heard if the bolt goes in too far it can lock or damage the pump, any help is greatly appreciated and thank you!
Are they white teflon washers only, or are they white washers lightly pressed into an aluminum ring?
If white washer only, those are for 407 lines.
If the Teflon with aluminum, they will work, and seal better than the steel and copper washers.
Or in a pinch you can just use the metal washers from Stanadyne. Any Deere or Agco dealer should have them, or local pump shop.
