MinnesotaFarmall Posted May 7, 2021 Share Posted May 7, 2021 Well it happened... The big hoss is broke down again. Checked the oil before it went out, and it was good. Apparently, pinion bearings disagree. Front pinion bearings went out, and locked the front end up. Hoping to salvage it and see what happens. Called case ih and the parts are non existent!! Holy moly.... I'll have to call local bearing house and see what happens there. Anyone got a good line on where to get parts? Doesn't look like too bad of a job to fix. Quote Link to comment Share on other sites More sharing options...
jass1660 Posted May 7, 2021 Share Posted May 7, 2021 Several of the axle parts can be sourced at truck shops. Quote Link to comment Share on other sites More sharing options...
MinnesotaFarmall Posted May 7, 2021 Author Share Posted May 7, 2021 25 minutes ago, jass1660 said: Several of the axle parts can be sourced at truck shops. Sounds legit, but I know through working at a truck shop that they need serial numbers/part numbers. Don't have either. Searching through old posts there used to be a place called trax or trac-4. I can't find them now. Quote Link to comment Share on other sites More sharing options...
Nebraska1206 Posted May 7, 2021 Share Posted May 7, 2021 @Ed Leaman is the man you need to talk to 2 Quote Link to comment Share on other sites More sharing options...
MinnesotaFarmall Posted May 7, 2021 Author Share Posted May 7, 2021 Was going to give him a call in the morning too. Done business with him before, enjoyed the transaction. By the way if he sees this, this is one of the creations from his back plate he sold me. Quote Link to comment Share on other sites More sharing options...
Torque Posted May 8, 2021 Share Posted May 8, 2021 The Elwood differential is an Eaton H110. GM used it from 1941 (army trucks) all the way to 1979 (motor homes) and in 1 1/2 ton trucks, so parts are available surplus or truck shops. Quote Link to comment Share on other sites More sharing options...
MinnesotaFarmall Posted May 8, 2021 Author Share Posted May 8, 2021 6 minutes ago, Torque said: The Elwood differential is an Eaton H110. GM used it from 1941 (army trucks) all the way to 1979 (motor homes) and in 1 1/2 ton trucks, so parts are available surplus or truck shops. As in the whole assembly or just the differential and pinion assembly? Quote Link to comment Share on other sites More sharing options...
Torque Posted May 8, 2021 Share Posted May 8, 2021 9 hours ago, MinnesotaFarmall said: As in the whole assembly or just the differential and pinion assembly? GM never used that axle as a steering axle except in army trucks and they were never planetary final drive, so no, not the whole assembly. The planetary finals was a Spicer conversion and I have seen them on non steering industrial equipment and the Elwood. The center section is the same as the army trucks except ratio and I think the steering knuckle is the same also but the axle and spindle are different for the planetary. The Elwood uses U-joints and the army truck axles had rezepa joints for steering. Quote Link to comment Share on other sites More sharing options...
MinnesotaFarmall Posted May 8, 2021 Author Share Posted May 8, 2021 Only one of ours has u joints. The other are the big ball and socket joints, if they are called rezepa?? Quote Link to comment Share on other sites More sharing options...
Torque Posted May 9, 2021 Share Posted May 9, 2021 Miss spoke, the army trucks used Bendix joints, they have 4 balls between ears for steering. The one Elwood I had apart had rezeppa joints, they have a bell with grooves for the balls (6 I think) and a smaller internal driver with grooves to match. Quote Link to comment Share on other sites More sharing options...
Ed Leaman Posted May 13, 2021 Share Posted May 13, 2021 That's a good looking tractor! plate looks like it worked too! If your gonna fill that cart you may want to add one of these if you have any hills. As for the differential parts, should be able to source from truck parts but it takes a knowledgeable parts man. Will need the ratio and casting numbers or better yet part numbers. Sometimes found stamped on end of pinion and if lucky on the ring gear. There is a good place in Mn. but cant think of the name tonight. ed 2 Quote Link to comment Share on other sites More sharing options...
MinnesotaFarmall Posted July 22, 2021 Author Share Posted July 22, 2021 Finally got around to getting the front tore down. Plenty of junk in there to clean out. Everything looks serviceable, so going to do a good year down of ring gear set and clean up bearings and check gears in diff. Have to find a source for the front seals on the big ball ends. There's a felt seal and a rubber one. Case IH says N/A. 1 Quote Link to comment Share on other sites More sharing options...
Jeff-C-IL Posted July 22, 2021 Share Posted July 22, 2021 On 5/6/2021 at 9:20 PM, MinnesotaFarmall said: Was going to give him a call in the morning too. Done business with him before, enjoyed the transaction. By the way if he sees this, this is one of the creations from his back plate he sold me. DO you actually use this full of grain? I have a 500bu grain cart & a 666.....and I never even considered using the 666 on the cart. The hitch on the cart, both the top & bottom of the U is almost as thick and 2x as wide as the drawbar on the tractor! I pull it with a JD 7410 (120 hp, more like a 1066), and that's marginal on my flat terrain, IMO. Curious if you find this works for you? Quote Link to comment Share on other sites More sharing options...
MinnesotaFarmall Posted July 22, 2021 Author Share Posted July 22, 2021 38 minutes ago, Jeff-C-IL said: DO you actually use this full of grain? I have a 500bu grain cart & a 666.....and I never even considered using the 666 on the cart. The hitch on the cart, both the top & bottom of the U is almost as thick and 2x as wide as the drawbar on the tractor! I pull it with a JD 7410 (120 hp, more like a 1066), and that's marginal on my flat terrain, IMO. Curious if you find this works for you? No, we don't. It had a little bit of shmutz left over in it that didn't get cleaned out. I was moving it out of the yard to park it for summer storage so decided to just use what was already running. We had our 1086 mfwd on it, and it was about all it would want if it started to get wet. 1 Quote Link to comment Share on other sites More sharing options...
Reichow7120 Posted July 22, 2021 Share Posted July 22, 2021 4 hours ago, MinnesotaFarmall said: No, we don't. It had a little bit of shmutz left over in it that didn't get cleaned out. I was moving it out of the yard to park it for summer storage so decided to just use what was already running. We had our 1086 mfwd on it, and it was about all it would want if it started to get wet. Brent 420? Looks like ours except yours is green and ours is red and we have a tarp kit on ours Quote Link to comment Share on other sites More sharing options...
MinnesotaFarmall Posted July 22, 2021 Author Share Posted July 22, 2021 I believe you are correct on that. Nice rigs, it's not ours, a friend's, but it stays here now and again. Quote Link to comment Share on other sites More sharing options...
Torque Posted July 23, 2021 Share Posted July 23, 2021 The bell seals are the same as the M135/M211 6x6 army trucks built by General Motors. 1 Quote Link to comment Share on other sites More sharing options...
MinnesotaFarmall Posted July 28, 2021 Author Share Posted July 28, 2021 Got some more work done on it. Removed ring gear and cleaning up the diff carrier. Looks like bearings have went out once at lease and ground enough to be needed repairs. Also found a nice crack on axle housing. I think I'll be able to repair it in house. 1 Quote Link to comment Share on other sites More sharing options...
