The torque pattern in the TD-14 service manual is not the correct illustration for head #8064DA on my tractor.  It's the right head according to my TC-25-B parts catalog.  Can somebody provide me with the correct torque pattern.  Here are a couple of pictures---left to right, front to back.
Vic
It looks like I'm not going to come up with a torque pattern so I've made one.  Does anyone see anything wrong with the one I made up?
Vic
I don't know if the 14 and the 14A heads torque up the same, but I will try to look tomorrow.  Otherwise your pattern looks like it would work just fine, based on other patterns I have seen over the years.
The wrong torque sequence illustration in my service manual says that it is for "14 Series heads".  From what I've read,  going in a zig-zag pattern from the center out is the general idea.
Vic
Vic,
Attached is the tightening sequence from my service manual.  Slightly different from yours.  Let me know if you need anything else
Gene
That is the exact illustration I'm talking about that is not my head.  Just for starters, my head has two intake ports & three exhaust ports.  It has two outside rows of 8 studs & one row down the center with 5 studs.  My version is shown above.
Vic
Vic,
That is what the drawing shows studs #1, 2, 3, 16 and 19 (5X) in the middle. Studs #5,6, 8, 10, 12, 14, 17, and 21 (8X) next to the injectors.  Studs #4, 7, 9, 11, 13, 15, 18, and 20 (8X) next to the intake and exhaust ports for a total of 21 stud bolts.  should work for your application.
OK, I've got it!  That's a poorly drawn illustration.  It looks like I could use it by looking only at the positions of the numbers, not the positions of the stud representations.
Vic
yes, a little confusing when you first look at it
