Oil Filter Base Leak, 400 Series Engine
Is there some secret to getting this to seal up?  The 1466 had a pretty bad leak  between the mount and the engine block, so I took the base off and sanded it flat (it was very warped).  Called the dealer and was told that the gasket is NLA.  I used Loctite 515, laid a bead around each of the ports, and remounted it.  Let it dry for a couple days.  After 4 hours of run time, I have an external leak at the mount that is worse than it was before.  Just wondering if there is a different product or procedure I should be using?
Thanks!
Chad
Thanks!
Chad
I had to change that gasket on my 1460 afew years ago  and found out you couldn't buy it separately only in a complete gasket set , I got some gasket stock material and made my own I used sealer on it as well problem solved never leaked at all
45 minutes ago, pirlbeck said:
The gasket is available from A&I
Making it is quicker and cheaper and also in the heat of harvest can't wait that long for shipping
34 minutes ago, Dan Robinson said:
You also need a dab of 515 on the bolts, 3 of them go thru to the crankcase and could leak down the threads.
That is good information.  I should've looked at it closer...  I'll be sure to do that.  Thanks!
I did buy the gasket, but I was hoping not to have to wait for it.  I have a bunch of land I need to work yet unfortunately...  Thanks for the info!
43 minutes ago, Haywire said:
I’ve had a base with a hairline crack in it
I'll take a look at it again when I get it off.  I didn't see anything last time, but it could've cracked when I tightened it down.  I'll take a look at it when I get it off.  Thanks!
3 hours ago, tractorholic said:
Have you checked with International trucks? I thought I was told you could get the gasket from them.
If the one I got doesn't work out, I'll give them a try.  Thanks!
^^^That's usually the missing step to a successful repair.
Had one that was cracked also. Local bone yard had one and made my gasket along with 515 sealant
