7120 return fuel line?
the return line o our 7120 just started leaking right by the spot where it has a holder around it, so we could go tommorrow could the line be brazed ? its not leaking bad and i am sure the vibration where the holder is where the hole is, or wait till monday for a line?
What he said.  They aint that much.  And iirc ours was 1 day out in Portland at the cih warehouse.  Even a diesel shop could make one i bet...or switch to hose.  Iirc my 8930 is hose and the 7140 [rip] was steel...?
12 hours ago, lorenzo said:
Wait for a new one. Fix it right the first time.   If they have it in stock.
X2 but if you need to use it braze it up til you can get one.  Another quick fix might be a compression fitting or a small piece of hose over the hole with a hose clamp.  On a return line it won’t take much to keep if from leaking.
