806 with rd injection pump
You can repair them on the tractor just takes some patience. Here is a link to a youtube video I made a few years ago. It ends fairly quickly but if you reverse the process I show you can put it back together. I have help several people through this process over the years so feel free to reach out to me for help.
13 hours ago, Dan Robinson said:
If it's just the throttle shaft seals, they have the same oring as the Roosa Master pumps.
Dan, The o-ring size is 9/16” OD x 3/8”ID x 3/32” thick. On the RD the o-ring groove is in the collar that’s pressed in the housing. It’s been mentioned before of the o-ring groove being on the shaft using the Roosa master o-ring you mention but I have never seen that style in the several RD pumps I’ve worked on.
Oops my bad. Maybe it was something else. Your the expert!
On 5/2/2021 at 2:25 PM, Swade102492 said:
IHBRAD thanks for the video that helps alot. I've seen a couple different seal kits out there but they all turn out to be for a roosa
All o-rings for those pumps are a standard size and can be had from your local hardware.
