1486 diff lock question
Pike
Is there any reason I couldn't change the momentary switch on the dash for the diff lock to a toggle switch? I'm not worried about forgetting and leaving it on, and sometimes I don't have enough hands to be pushing that button when I need it on. Thanks
I would recommend against doing that unless you added a pair of brake pedal switches and a latching relay that would deactivate the diff lock solenoid when you pressed one of the brake pedals. All for safety to switch off the diff lock if your hands are busy and you need to not go straight anymore.
