1566 MCV Valve
Vanstractors
Steering is stiff on this 1566 that,s under restoration .As usual some slop in front end so complete new front end Thrust bearings were a lot better than some .But while checking on mcv valve found spring 8 Flow Control Valve broke .Could this be a culprit to stiff steering ?While the tractor is apart was going to put new mcv kit in .But if this could affect the steering may replace spring and take a chance.Thank You !
