756 brakes
François02
hello guys
I was searching for remplace my brakes on the 756 and I found some kits with spings on it
But I don't have any spring on my brakes. Does it exist 2 differents mounting? My 756 serial number is #17871 (it is an early 1970 model; serial number starts at #17832 in 1970 according to tractordata)
You can see on the pics I haven't springs #10 but I have tubes #38.
Is it normal or d I need parts?
Thanks for your help!!!
You will need to reset those tubes(adjusters) with snap rings on them when you put new disks in.
Check a manual but I think they need pushed back down so first snap ring is 3/4" from top.
I use a deep socket that fits over end but will push on snap rings. Use a bench vise to push them down.
Somebody chime in if I'm wrong on that measurement......been a while
thanks for your replies
I check the operator's manual and didn't find anything about the snap rings. Perhaps it is on the workshop manual? If someone has it in informatics version... I'm interested
