Is the Scout 80 negative or positive ground and where should I attach the Jumper cable to see if the starter will turn?
See where the negative terminal cable goes if its negative ground its going to be bolted to the frame or an engine bolt if its positive ground the negative terminal cable will go to the starter motor as for jump starting its always positive to positive and  negative to negative connections no matter what vehicle your using
remember all the IHC 12V duty duty  vehicles as being negative ground, just like the rest of the American vehicles in that era. My 1960 B100 was. 3 speed  on the tree with a granny low .
All scouts negative ground
thanks!
