Changing to international 238 motor to 4BT cummins engine
I'm changing out the International 238 engine in a International TD8 dozer. I'm told I can use a 4BT cummons motor to replace it. My 238 is a Turbo Diesel engine.
1 st. Does the 4BT non turbo motor the same internal parts as the 4BT turbo motor, so I can just add a turbo to it and have it work, or does it have different internal parts that will not take the extra power from the turbo?
2 nd. What are the adapters (bell housing, fly wheel and'or center bushing) I need to make the conversion from the International transmission to the the cummons motor, so I can hook up the flex palte to the new motor?
Any help is appricated.
Tom
