Hello all, International E200 scraper
That’s excellent Ethan!
thank you very much. Do you happen to also know what the hydraulic filter numbers are by any chance?
Sorry for so many question but I’m getting excited since I’m narrowing in on what I need from you and all the other help on here.  If I can find out the hydraulic filter number I need I’ll get all those ordered.  Then I’ll be able to make the drive up to Georgia and put a front tire on and change liquids and filters and hoping i can get it moving onto a trailer. If not I’ll tow/push it on the trailer to get it back here to my place.
thanks again for the help.  It is very much appreciated!
Doug
You may have lost the drive gear on the flywheel that turns the convertor which drives the hydraulic pumps. Check the trans oil before you start the engine - should be over full as is susposed to be checked with engine running. Start engine and oil level should drop if not you probally lost drive gear will have to pull trans to get at it.
