New Englander Posted April 17, 2021 Author Share Posted April 17, 2021 2 minutes ago, TomH said: #4 Could have had magneto troubles back then. A good friend and colleague of mine is also an A&P, IA. He restores Stearmans to show winners and also does some maintenance work on the side. There were guys in the hangar opposite his who always has a terrible time starting their Cessna 150. When their annual was due they approached my friend to do it and he accepted. When he went to taxi the plane to his hangar he couldn't get it started. It had gas and compression. Magnetos had never had a 500 hour inspection so he pulled them and sent them to the shop. They called and asked if the mags had come off a running engine. Points were closed up and I think one distributor block was cracked. Guys got their plane back and were amazed how well it ran! My 182 was giving me intermittent mag checks - every now and then it would run like crap on one then be ok, similar to a piece of lead in a plug. I checked the mags in flight only to find one dead. 500 hour nowhere near due, found condenser lead broken but ends touching, giving me the intermittent checks. I suspect the internal airflow at cruise RPM was opening the lead up. Good reason to have redundancy! The condenser lead in the Slick mags is also the "P" lead so if it stayed open on the ground it could result in a "HOT" mag, one that was on even with the switch off, so the engine could possibly fire if the prop was moved and fuel available. We always treat any prop as HOT just in case. 1 Quote Link to comment Share on other sites More sharing options...
Pukeko Posted April 17, 2021 Share Posted April 17, 2021 57 minutes ago, New Englander said: Where would the rotor RPM be with the engine at the top of the red? Reminds me of a pilot who said while spraying they sometimes operated in the black. Of course I bit and said "what's operating in the black?" The reply: That's the area ABOVE the red.? EDIT; Of course in a helicopter the dual tach would have BOTH needles in the same place. Fixed wing guy here. Maintenance only on rotor wing stuff. When I said "top of the red" ,that is at and not exceeding 2800rpm.The rotor rpm was within the correct parameters for the corresponding engine rpm.I forget the "actual number" for the rotor rpm at 2800 engine ,as the last time I flew that particular type of aircraft was 1985. 1 Quote Link to comment Share on other sites More sharing options...
Pukeko Posted April 18, 2021 Share Posted April 18, 2021 7 hours ago, Pukeko said: When I said "top of the red" ,that is at and not exceeding 2800rpm.The rotor rpm was within the correct parameters for the corresponding engine rpm.I forget the "actual number" for the rotor rpm at 2800 engine ,as the last time I flew that particular type of aircraft was 1985. New Englander, I found what I was looking for ;max main rotor rpm =258 @104 %, min 170 @68 %. These types of aircraft and other Sikorsky models had a relatively slow rotor speed,and the slow speed would sometimes contribute to another "exciting " phenomena , "retreating blade stall" under certain conditions . That is a real attention getter,needless to say.The main problem letting rotor and engine rpm getting too low and pulling more collective( main rotor pitch) it will further decay,contributing to over boosting due to the low engine rpm,and worse ,putting you into a sometimes non survivable situation.( rapid descent vertically )The hulls on those machines contained a lot of magnesium ,and they can go up like a christmas candle in only a few minutes !! Also you comment re dual tach totally correct,thanks . Quote Link to comment Share on other sites More sharing options...
Dave Downs Posted April 18, 2021 Share Posted April 18, 2021 22 hours ago, New Englander said: I think you're on the mark here. I really don't see why wide plug gaps would lead to detonation as much as an over boost would, especially since it's not known exactly when the detonation took place. One witness stated he heard a power increase just before impact and that's when an extreme over boost could have occurred - in the last desperate seconds in an attempt to save it. For those not familiar, at that point the props should have been in max RPM, sort of like low gear. Advancing the throttles on a supercharged engine to to a very high manifold pressure even in "low gear" can cause extreme detonation. I've seen cylinder heads actually pushed off the barrels due to extreme over boost. Just read the report - with my overwhelming 1500 hrs + of flight experience in piston-powered aircraft (about 1000 in the same 150hp Citabria) I was amazed at how badly things were handled. Just the statement that the flight engineer/loadmaster routinely did not occupy a belted-in seat violates one of my earliest instructions in aircraft operations. When I first started flying I would fasten my belt just to taxi the plane to the fuel pumps (and continued to do so throughout my flying years), and this was in a era when very few people wore seatbelts in their cars, in fact in 1965 few of us owned cars that had seatbelts!! I do know a bit about the operation of high-performance gasoline piston engines (of the hot-rod type) and never heard of or experienced detonation due to overly wide spark plug gaps - detonation (and catastrophic engine failure) was often the outcome over over-boost!!!! Wide plug gaps usually resulted in missing/misfires at high rpms. 2 Quote Link to comment Share on other sites More sharing options...
m.c.farmerboy Posted April 18, 2021 Share Posted April 18, 2021 There are Old pilots and there are Bold pilots But Not Many OLD,BOLD PILOTS Quote Link to comment Share on other sites More sharing options...
Dave Downs Posted April 18, 2021 Share Posted April 18, 2021 Another thought - @New Englander The report mentions that the passengers were permitted to leave their seats and walk around while the aircraft was still in it's initial climb configuration. Doesn't that violate the FAR's? - not that it contributed to the accident but it seems like a very poor practice. I recall one of the early words of wisdom imparted by one of my flight instructors was that takeoff/climb was more dangerous than landing. When I flew on the EAA B-17 many years ago there were no jump seats, all the passengers occupied a crew position (except for the tail gunner) and if my memory is correct we did not leave the seats until the aircraft was in a stabilized cruise configuration. I'm just surprised at how poorly the flights seem to have been operated - which unfortunately matches the poor maintenance. Quote Link to comment Share on other sites More sharing options...
New Englander Posted April 19, 2021 Author Share Posted April 19, 2021 11 hours ago, Dave Downs said: When I first started flying I would fasten my belt just to taxi the plane to the fuel pumps (and continued to do so throughout my flying years Always a good idea, especially in a light plane. The guy in the jet or the air taxiing helicopter may not notice you or even have any idea of your vulnerability. I've seen bag carts, LD3 containers and even a van blown away. Company policy and regulation has always been belt on for taxi, even if repositioning to parking. 4 hours ago, Dave Downs said: Doesn't that violate the FAR's? The regulation states essentially taxi, TO, and landing, so an interpretation might include the below climb segments at most. Note that final segment, with no controlling obstacle ends at 1500'. I think that's as far as takeoff seat belt requirement could be stretched. Quote Link to comment Share on other sites More sharing options...
