nate 889 Posted April 7 Share Posted April 7 So my brother just bought a 1872. Bought it knowing it had issues. The hydraulic lift does not work. The cylinder is fine. There is absolutely no hydraulic pressure to the cylinder. The power steering works just fine. Any ideas?? Quote Link to post Share on other sites
iowaboy1965 2,748 Posted April 7 Share Posted April 7 Steering gets priority similar to the big tractors I believe. Would find priority valve and check function? Quote Link to post Share on other sites
nate 889 Posted April 7 Author Share Posted April 7 So we checked a few things quick. Has 300 psi charge pressure which I believe is high. Took out charge relief and implement relief valve and springs are in tact. That is all I had time for. Quote Link to post Share on other sites
Mr. Plow 1,010 Posted April 8 Share Posted April 8 Valve body isn't loose on the steering column is it......(lever moves whole valve not just the spool)? PS does have priority, priority out goes to lift valve in, the both dump to a common dump/return line with a tee. Quote Link to post Share on other sites
Mr. Plow 1,010 Posted April 8 Share Posted April 8 Here is the circuit diagram. Quote Link to post Share on other sites
Mr. Plow 1,010 Posted April 8 Share Posted April 8 Nate, was that 300# on the hydro itself, or with a gauge in a remote and the lever deadheaded. 300# is a little high for charge loop (min 200psig with hyd. lift) but not too bad. The remote valve should dead head around 800 psig (gauge on a male quick coupler nipple). I still wonder if the valve is loose on the column...... Quote Link to post Share on other sites
nate 889 Posted April 8 Author Share Posted April 8 We just figured it out. Previous owner had the lines mixed up on the power steering ports. The had the “out” port and the “aux” port mixed up so the power steering worked but it was dumping oil rather that feeding the auxiliary valves. There is a few things on this thing we are wondering about previous owners mech ability. Crank seal was leaking and it was clearly wrong seal. 1/16” away from crank!!!! 1 1 Quote Link to post Share on other sites
Mr. Plow 1,010 Posted April 8 Share Posted April 8 Glad you got it! Quote Link to post Share on other sites
