mounting ag-15 antenna 756 open station
Any suggestions on best location.
Front of tractor or right behind the seat? ag-15 has 3 magnets and also a large threaded hole in the center, may be pipe threads? No instructions in box or on their web site that I have found. Cab tractor or rops with a canopy is simple. Needs to be above the straight pipe so it does not affect signal, that's all I know for sure. Hope you guys have some input and any pointers on the ez guide 250.
Thanks
When you do your setup, I believe you can set an offset, so it doesn't have to be on the centerline of the tractor. Been a long time since I did a GPS install and never did anything less than a Trimble 500, so I could be wrong on this. If you can do an offset, I would think you could mount on one fender or the other, it should be far enough away from the stack to not be effected.
I wouldn’t sweat the exhaust pipe messing with the signal.
