Loader For 395
dbshelton
I have a 395 that I bought new in 1991. After all these years, I have decided that I may install a Loader on it. It has no remote hydraulics on it. Besides finding a Loader that will fit, what all do I need to add to do this job?
There is a similar thread on here about adding a loader to that series of tractor with no remotes. Normally the power beyond is built into the remote valve and you run a hose to your loader valve and return to the bung on the sump on the rear end.
2200 loader is the "best fit" and was made many years so somewhat common. It is not quick attach so keep that in mind.
I assuming it does have 3ph though, correct?  If no, you aren't getting a loader.  If yes, your going to have to do some plumbing.  I think you can unhook a line and tie into it, but will need to pull a plug for return.
2200 or 2250 loader are the correct models.  2200 is mounted.  2250 is quick mount. Both should be super easy to find, but may not be close to you.  Auction time, Big Iron, Irons each and just a few places to look along with local listings.  Google helps a lot.
