GMC TopKick 7000 with a hop
10 hours ago, mikem said:
I'm a loooong way from an expert, but how do you "time" 3 U-joints in a drive shaft?
I believe that the front and back one are supposed to be in phase
  • Replies 137
  • Created
  • Last Reply
Top Posters In This Topic
Popular Posts
Congratulations,  you found your problem. I'm a little put out. I said it was most likely a driveshaft problem before jmech but he gets the credit! You Yankees are discriminating against us
Did the hoping stop now that Easter is over?
The problem is in fact that you have been using Hy-Tran inside the driveshaft when you should have been using Official Yellow Wonder Bucket Fluid!!!
Posted Images
Jack up the rear end and set the frame on cribbing so the wheels are 6" off the ground.
Then with the box up, and someone watching the rear end and driveshaft, start it up and gently bring it up to speed.
Do this slowly as this can get out of hand and if as bad as you say, could try to jump off the cribbing.
If it is that bad, then either the driveshaft will start to wobble, the rear end will start to jump, or both.
I am betting money on the driveshaft.
Most bigger towns have a driveshaft expert who can spin your shaft and find any issues.
10 minutes ago, acem said:
But have you checked the phase of the flux capacitor?
I lent out my Flux Phasometer, haven’t gotten it back yet
  • Haha 3
I'm with the boys who are thinking it's the driveshaft ,  most likely out of phase
Snap a piccy of the driveshaft
https://youtu.be/Idk3BVDVHq4
Ok, driveshaft pics and findings, also video. I have 5 degrees at the tail-shaft of the trans and 5 degrees at the pinion, the joints are all in phase, i have tried turning it so they were not and the results did not change. Please excuse the video quality, it looked better on my phone but the youtube upload lost something.
also the vibration does persist even when coasting in neutral when jacked up.
1 minute ago, m.c.farmerboy said:
are those napa brand jack stands?
Hard to find a Jack stand made in USA, these were made locally.. i am into that .
If you shortened one of the line shafts did you have it balanced?
with the truck in the air and wheels turning slowly apply the brakes and see if there is a change
all the u-joints must be in phase
can you drive it on the road and video the vibration ?
Make sure there is enough play in the jack shaft. If too tight it will bind .
Did not balance shaft, made by local engine builder, joints are in phase in that the pinion yoke, slip portion of the lower shaft and trans output yoke are all in alignment.. as In pointed at each other.
Jack shaft?
9 minutes ago, acem said:
Have you verified the pto is shutting off?
It's a long shot but those ptos can vibrate.
Thx-Ace
It is, also direct mount pump and cable control PTO i can feel it disengage.
You have to be careful who you lend tools to.
Tape a quarter to the driveshaft. If it gets worse move the quarter around to a different spot. See if it improves. Keep moving it around the shaft til you hit a sweet spot. Weld a washer on. Duct tape and 25 cents may fix it.
11 minutes ago, 79vking said:
Driveshaft Phasing & Its Importance - Managed Mobile, Inc.Looking at your third pic after the video it looks like that shaft is incorrectly phased.
I have tried it both ways, however if i turn it 90 degrees that puts the trans output and pinion put of phase, i have been going on the assumption that keeping the phasing of those 2 correct was more critical
I'm no expert but I don't think the trans yoke and the diff yoke matter. Just went out in the shop and looked at a truck ant the trans and diff are not in phase. The yoke in each shaft have to be in phase. Think of the original set up of this truck, when you engage the transfer case from road to pump it does not phase. Just the independent shafts on each side are phased.
