2A Hay Conditioner
Red666
IH made a #1, #2, 2A, 33 & 34 hay conditioner. Then there was that strange 816 thing. There are no 9' conditioners. You should be able to condition from a 9' cutter bar provided the ends are tucked in to 7'. Otherwise the rollers try to suck the hay in from under the tires & it will plug. If it's heavy, you may need to adjust the rollers so they're a little further apart. Make sure it's done evenly.
we had a model 33 7ft. rubber rollers we pulled behind a 100 semi-mount mower before we had haybines.
