350UD International D-193 Continental engine
Downrb92
23 minutes ago, MarcusM said:
Hey Robert!
I just ordered a manual for the same exact tractor and it should be here this Saturday.  I will send you the pic of the sequence and torque specs as soon as it arrives.
-Marcus
Thanks Marcus
appreciate the help
those brakes are simple  take apart clean inspect.per MANY prior posts.
90% need replaced, if the disc is under .45 ,7/16" replace...,only .52 when new, if new pads rub springs, actuator is done also.
