Help! I need a parts guy
ihrondiesel
I’m putting seals in the rear axles of one of my 5488’s. Right side, no problem. Left side, ggrrrrrrrrr!!! Two different size seals on the tractor. The right side has a bushing that extends well out past the axle housing, at least 1/4”. The left side side bushing sits at exactly the same position as the end of the axle housing. That makes it a little tougher to get the seal started. To make it worse, someone has been in there and put a speedi-sleeve on the bushing, making a little lip for the seal to climb onto at the same time. No way the new seal is going on over that without folding over. So, looking on the parts website, they show 4 seal numbers and 2 bushing numbers. Does anyone know the differences in these part numbers?  My local parts guy is OK but he can only order something and see what shows up to compare stuff.
Here are the part numbers:  seals are 143926C1, 143927C1, 1277120C91 (pkg), and 1277121C91 (pkg) - part #27 on the picture. Part #19 is the bushing, part numbers are 137771C2 and 143895C2.
TIA,     Ron
Thanks, striker!  So the new west ring can be installed from the outside?  Wow, that would make my day if that’s the case!
I'd like to help you out but the parts I came with are a bit bent up and in generally crappy shape, a few of them even missing, the ones I got left I figger I'm a gonna need to make it till the big bell. And Ifn ewe can't laff at yourself then life ain't worth living. Good luck with your parts search. bwwwwaaaaahhhhhaaaaaa...
 I just couldn't resist.....
