Trying to remove the cover where the shaft is for the shift lever for forward and reverse .
1965 IH TD 9 , The seal on the shifting shaft started leaking hydraulic fluid , I removed all the bolts and nuts and the two snap rings , The cover is loose but will not come off,        Any ideas..   Thank You
