Battery draw
1086 started all winter long in the cold. Now that it’s warmed up alittle I changed all the halogen lights over to LED other than the flashers. Can’t keep the batteries charged now. It’s dead every time I go to start it.
Could I have messed something up or is it just time for new batteries?
Unless you totally messed up wiring for the lights somewhere by the switch, turning off the light switch should turn off any power/draw by the lights.   My guess is your bateries simply gave out.   Easy to test - charge them up, and then disconnect them for 24 hours.  Then   1) test them with a battery load tester or 2) hook them up and try to start the tractor.    If the tractor starts just fine - examine wiring.   If the tractor turns over but seems sluggish, you may have 1 bad battery that is killing them both.
How old are the batteries ? Are the connections clean and tight ?
The batteries are not new and the connections are not perfect. I just thought it was odd it would start at 10°F plugged in but deader than h*** when it’s 63.
