TD 15 E transmission
Farmer bought this one for parts they said the trans was out of it it only has 100 lbs main pressure but convertor spins full speed right away you can feel it engage but wont move . Going to check strainer maybe just clogged or bad pump
Those transmissions don’t generally give much trouble unless abused. . Our experiences have been the converter or pump. The 1 I’m working on has decent pressure until it gets hot then falls on its face. Will move but not well. Filters are full of aluminum also. Did he buy it on Craigslist?? I seen 1 on there cheap.
