Rfh Posted March 1, 2021 Share Posted March 1, 2021 Putting a ta in my 706 and was rebuilding the mcv and it had no brake check valve or spring. Also the inner spring in the pressure regulator valve was missing. The tractor would get hard of steering throughout the day. Link to comment Share on other sites More sharing options...
rfh129 Posted March 3, 2021 Share Posted March 3, 2021 I found a spare MCV and it had the plastic brake check valve. So I will have it now. What ever it does Link to comment Share on other sites More sharing options...
snoshoe Posted March 3, 2021 Share Posted March 3, 2021 12 minutes ago, rfh129 said: What ever it does Keeps brake valve from draining when shut down. Link to comment Share on other sites More sharing options...
snoshoe Posted March 3, 2021 Share Posted March 3, 2021 On 3/1/2021 at 4:47 PM, Rfh said: inner spring in the pressure regulator valve was missing. Original pressure in 706 was somewhere around 180 psi. Probably didn't have inner spring. Don't remember for sure. Check your pressure. Link to comment Share on other sites More sharing options...
dale560 Posted March 4, 2021 Share Posted March 4, 2021 On 3/1/2021 at 4:47 PM, Rfh said: Putting a ta in my 706 and was rebuilding the mcv and it had no brake check valve or spring. Also the inner spring in the pressure regulator valve was missing. The tractor would get hard of steering throughout the day. Lots of people lost the check valve or never put it in. Another trick popular years ago , guys would plug the hole and leave check valve out. Link to comment Share on other sites More sharing options...
snoshoe Posted March 4, 2021 Share Posted March 4, 2021 Brake check valve is in top of mcv. Will not affect steering in anyway. Plugging it would mean loss of brakes. Steering check valve is in center section behind bottom of mvc. Which were you missing? Link to comment Share on other sites More sharing options...
