D236/282 Precup installation direction
I pulled the injectors out of my Galion 503/D236 and had them tested. I did not pull the precup's out of it. Before putting the injectors back in I want to verify which direction the cups are in. I know they say top on them to show which way they go in, but I do not want to pull them out if I absolutely don't have to right now. What I am trying to confirm is if you look down in the hole, should the hole into the cylinder be on the top or the bottom?
