Farmall m bearing axle and differental bearing
Im trying to find skf bearing numbers for the following bearing. ive been told to make sure i get max fill bearing. I bought some bearing from a tractor supplier and got a no name bearing that wasnt a max fill.
Can someone tell me if these bearing are max fill bearing. if not can you help me out.  also need help with  st310a
axle
st223             skf 214j
st310a           skf
differental
st269a           skf 212j
st223             skf 214j
14 hours ago, Dell said:
I’m going to be tractor pull only
Then you don't need a full compliment bearing.  Matter of fact, if you're looking for hp to the ground, going to fewer rollers in a bearing reduces drag and puts more power to the ground.  This had been proven on dyno runs.
Just get bearings and go with them.  Tractor pulling is nothing like pulling equipment all day.  It's hard on equipment in a much different way.  Whatever bearings you get will likely outlive the machine that just pulls a sled.
19 hours ago, J-Mech said:
What is the number on the bearings you removed?
Its a  new departure 1214   steel shield on one side
1 hour ago, lightninboy said:
What about moderate field use and 100-mile tractor rides?
Still no reason for full compliment bearings.
+100 mile tractor ride to a pull maybe , i remember doing that as a kid to fairs out in central NY . Boonville . Franfort, Brookfield fairs.  they never let  me pull.
  • Confused 1
