Gooseneck hitch on flatbed dump truck???
acem
I have a gn ball that rotates upside down so its out of the way when not needed, not sure of the make as it was installed on my truck before I got it.  Its handy to have it out of the way when you don't need it.
I have seen a b&w Weld in flip over ball in the bed brfore, I have seen factory built beds that cut a hole in the bed with a hinged door that allows access to the ball that was mounted to the frame rails with a 1 inch thick plate
yes  we have had it for 20 years
truck/bed /trailer mFG must be on same page
spring wedges turned down, bed and lift low profile.
much easier, tall neck on trailer with adj so it still fits std truck.
also installed a lock and pump lock out
IIRC it is about 1' different
all I can find,    pre internet,    bed breaks down
