jd4440 19 Posted February 23 Share Posted February 23 How do you tell the difference in park pawls between the early, late 5X88, and the magnums. I have 2, but no part numbers on them. Thanks Quote Link to post Share on other sites
TB5288 29 Posted February 23 Share Posted February 23 25 minutes ago, jd4440 said: How do you tell the difference in park pawls between the early, late 5X88, and the magnums. I have 2, but no part numbers on them. Thanks I have a 5288 and the part number IS on the pawl. Without part number, I don't know how you would tell the difference. I just went through a deal with the differences between the gears. Quote Link to post Share on other sites
Super A_sepa 124 Posted February 23 Share Posted February 23 The couple magnum pawls I have seen have had numbers on them as well. Quote Link to post Share on other sites
TB5288 29 Posted February 23 Share Posted February 23 Any chance you have a salvage yard nearby? Maybe they have each of them and maybe they have the part numbers one them and maybe you can determine what you have. That's a lot of maybe's but it's possible. Quote Link to post Share on other sites
jd4440 19 Posted February 23 Author Share Posted February 23 55 minutes ago, TB5288 said: Any chance you have a salvage yard nearby? Maybe they have each of them and maybe they have the part numbers one them and maybe you can determine what you have. That's a lot of maybe's but it's possible. I talked to the salvage yard here, and they don't have a good one but are looking for one they had that was bad, didn't call back yet Quote Link to post Share on other sites
TB5288 29 Posted February 23 Share Posted February 23 I have an early "bad" one I could get a picture of if needed. Quote Link to post Share on other sites
bitty 6,072 Posted February 23 Share Posted February 23 On the boxcar Magnum there was multiple ones used. ANY high speed euro ones used a different park paw, park paw cover and constant mesh gear was bigger ( causing the paw and cover needing to be different) Quote Link to post Share on other sites
88seriesrestorer 245 Posted February 24 Share Posted February 24 This is a as a rule statement. The new s/n paws were not stamped the old was. I go by the park lock gear part number. 120586c1 is old style. 1277036c1 is the new gear. Buy park locks by gear number then u can never miss match. 2 Quote Link to post Share on other sites
jd4440 19 Posted February 24 Author Share Posted February 24 57 minutes ago, 88seriesrestorer said: Buy park locks by gear number then u can never miss match Thanks for the reply Can you get the number off the gear from the side, or does it have to be split? What is the difference in the gears? I searched for info on this topic and couldn't find much Thanks Quote Link to post Share on other sites
88seriesrestorer 245 Posted February 24 Share Posted February 24 1 hour ago, jd4440 said: Thanks for the reply Can you get the number off the gear from the side, or does it have to be split? What is the difference in the gears? I searched for info on this topic and couldn't find much Thanks The number is stamped on the front of gear. Ther is a degree difference in the teeth. If you buy a new paw be sure to grind the button off between the two teeth. If you dont park will not hold. Mike Quote Link to post Share on other sites
jd4440 19 Posted February 24 Author Share Posted February 24 Thanks 88seriesrestorer Quote Link to post Share on other sites
