Allredallday 18 Posted February 15 Share Posted February 15 Just learned of an 8950 that a retiring farmer is going to sell of this Spring. I have been told by former salesmen, service techs, and parts personnel that there are differences between the two. Could you please list what is different between the tractors? If so, is it a pro or a con? I am interested in the HP, but don't want to get into a situation where parts won't interchange or become difficult to come by in the future. Quote Link to post Share on other sites
Thesd5488 376 Posted February 15 Share Posted February 15 Some stuff is supposed to be heavier like casting but other wise about the same you can buy a 8920 and make it work with a 8950 easy 1 Quote Link to post Share on other sites
bitty 6,097 Posted February 15 Share Posted February 15 Slight difference between the two. One thing overlooked on a 71-72-8950 is that they were all mfd, 3 remotes minimum, quick hitch standard (unless 3pt delete) I don't think any problems for parts between the difference between them make anything less available for one or the other. A few of the things I remember ... Axles are slightly larger inboard on the 50. Injection pump is different. Injectors are different I think. 1 Quote Link to post Share on other sites
ThirdGenRed 148 Posted February 15 Share Posted February 15 What was said above, plus larger exhaust pipe and I think the engine fan is direct drive, no fan clutch. Also, the external lift cylinders for the three point should be larger. 1 Quote Link to post Share on other sites
bitty 6,097 Posted February 15 Share Posted February 15 2 hours ago, ThirdGenRed said: What was said above, plus larger exhaust pipe and I think the engine fan is direct drive, no fan clutch. Also, the external lift cylinders for the three point should be larger. All of ours have a fan clutch.. new replacement muffler is the same diameter and I think it's all superceded to the 50 muffler. 40 and smaller could have been ordered with the big external lift cylinder. Quote Link to post Share on other sites
1566IH 5 Posted February 15 Share Posted February 15 I believe turbo is different also. I believe there is a video on YouTube that has the differences from CIH Quote Link to post Share on other sites
Gearclash 1,067 Posted February 15 Share Posted February 15 This thread covered the 7140/50 differences. https://www.redpowermagazine.com/forums/topic/138112-magnum-series-hp-question-for-the-ih-mechanics/ Quote Link to post Share on other sites
ThirdGenRed 148 Posted February 15 Share Posted February 15 16 hours ago, bitty said: All of ours have a fan clutch.. new replacement muffler is the same diameter and I think it's all superceded to the 50 muffler. 40 and smaller could have been ordered with the big external lift cylinder. Not any 50s around here that I am aware of, and I knew the fan was different, so I thought the direct drive fan was one of the changes, but nevertheless, the fan is different on a 50. Here is what the 89 series brochure says are changes to a 50 including the larger capacity fan and larger exhaust, makes sense they only offer the larger exhaust now, turbo diesels like a better flowing exhaust. According to the brochure, the upgraded external three point cylinders were available as an option for the 40 just like you said. 1 1 Quote Link to post Share on other sites
bobbyhuron 40 Posted February 15 Share Posted February 15 No expert but what about the shark grill on the 50s for cooling? Quote Link to post Share on other sites
1480x3 455 Posted February 16 Share Posted February 16 40 minutes ago, bobbyhuron said: No expert but what about the shark grill on the 50s for cooling? Believe it was only on the 7150 and all early 7200s from factory Quote Link to post Share on other sites
bitty 6,097 Posted February 16 Share Posted February 16 56 minutes ago, bobbyhuron said: No expert but what about the shark grill on the 50s for cooling? What is the shark grill? Quote Link to post Share on other sites
1480x3 455 Posted February 16 Share Posted February 16 12 minutes ago, bitty said: What is the shark grill? The screen in the sides of near the front 1 1 Quote Link to post Share on other sites
bitty 6,097 Posted February 16 Share Posted February 16 Pleated grill on the 89 series is a huge improvement for cooling for much more surface area 1 Quote Link to post Share on other sites
SDman 698 Posted February 16 Share Posted February 16 Hope the OP doesn’t mind me using his post for me to put up some more Magnum info out of one of my old 8900 series Magnum training books. First series of pics shows the rear end innards of each model...followed by the transmission specs in each model. 1 Quote Link to post Share on other sites
lorenzo 15,242 Posted February 16 Share Posted February 16 1 hour ago, bitty said: What is the shark grill? I think it’s on the 72xx models I always liked the looks of those. 1 Quote Link to post Share on other sites
560DT 15 Posted February 16 Share Posted February 16 didnt the 50 run a waste gate on the turbo ? Quote Link to post Share on other sites
bitty 6,097 Posted February 16 Share Posted February 16 3 hours ago, 560DT said: didnt the 50 run a waste gate on the turbo ? 7150, 7250, 8910-50 I believe were all wastegate Quote Link to post Share on other sites
J-Mech 1,489 Posted February 16 Share Posted February 16 Guys I'm pretty sure the waste gated engine came our as an "emissions" engine. Got the head off of our 7250 right now, and book lists the waste gated engine as a serial number break, "emission motor". I think that every engine built after that sn had a wastegate. Wastegate isn't exactly a hp building device as they limit boost. I haven't checked sn's, but I overhauled our 9330 last winter, no wastegate, and like I stated 7250 currently with a wg. I know the 9330 came out with more hp than a 7250. None of our 3 combines are wg either. 1688x2, 1666. 1 Quote Link to post Share on other sites
bobbyhuron 40 Posted February 16 Share Posted February 16 Sorry guys should of said shark gill. Like on sides of fish. Quote Link to post Share on other sites
Matt Kirsch 1,008 Posted February 16 Share Posted February 16 Just for fun I made a visual aid for the "shark gill" hood panels: Quote Link to post Share on other sites
Gearclash 1,067 Posted February 16 Share Posted February 16 3 hours ago, J-Mech said: Wastegate isn't exactly a hp building device as they limit boost. Correct. But the idea is to broaden the torque band. A waste gate turbo has a more restrictive nozzle that will build boost at lower engine rpm. Problem with that is at higher rpm the drive pressure gets too high and will exceed the boost pressure, which causes excessive egt and loss of high end power. The waste gate is there to bleed off that excess pressure. Then along came the variable geometry turbo. 2 Quote Link to post Share on other sites
lorenzo 15,242 Posted February 16 Share Posted February 16 On another note , since there’s a lot of magnum owners reading this, Was this step ( often called the window step). an option on the magnums. I can’t seam to find any rhyme or reason to it because on just about any model if you look at pictures long enough you will see some with it and some without it . I want to buy one and the bracket that is under it but can only find the aftermarket one . Now wait a second guys , before you jump on E-Bay and throw up a picture of the one offered by K& M that’s not the one i want. I want the OEM. Case IH version . Lots of guys took them off I’m being told so if your one of those guys and you want to sell it let me know. Quote Link to post Share on other sites
nepoweshiekfarmalls 2,360 Posted February 16 Share Posted February 16 Yes, they did make them. Used the same tread as the top step. We sold lots of them when I worked at the Case IH dealer. I wrote the part number in the front of the Magnum parts book back then..... maybe someone has it written down. Has to be one in someone's shed or parts department! 1 Quote Link to post Share on other sites
lorenzo 15,242 Posted February 16 Share Posted February 16 14 minutes ago, nepoweshiekfarmalls said: Yes, they did make them. Used the same tread as the top step. We sold lots of them when I worked at the Case IH dealer. I wrote the part number in the front of the Magnum parts book back then..... maybe someone has it written down. Has to be one in someone's shed or parts department! My cousins took it off their 8920 years ago when they put saddle tanks on . We can’t find it anywhere . Too long ago I guess. Quote Link to post Share on other sites
Gearclash 1,067 Posted February 16 Share Posted February 16 Since we are on the topic of cast aluminum Magnums steps--if (not when) you break one of them, they can be welded back together successfully. 1 Quote Link to post Share on other sites
