One Darn Nice 886
DirtBoyz07
This is one of my customers new to him 886. He just bought this from our local Case IH dealership and had it delivered to my shop and have me install LED lights , clean it up nice fix a couple things . He has a smaller dairy farm and it will be his daily chore tractor , box spreader, move bales , grind feed . The tach shows 3234 hours but the tach cable was bad and the guy that traded it in said it had approx 5000 hours . I ended up up putting a new clutch in it , went to grease the throw out bearing and found the live power shaft about to strip out and upgraded it to a 14” flywheel so he now has the bigger setup .
Its a really nice original tractor ??
  • Like 22
That’s a very nice looking 886!
By the looks of it it’s a late 78 or 79 model, it has the larger steps (unless they were changed) and the 360 engine (in late 79 they changed to the German 358)
 With all the improvements that should be a great tractor for him!
I put that cardboard on the left side so the -40 windchill doesn’t blow on the fuel lines , it works really good , I have done this for years , no fun putting fuel filters on out in a field ?
‘I don’t know when the brake was in the sn for the 358/360 , this one is a 1978 tractor I think , I forgot to look at the number .
‘Those splitting stands are the best I have ever used and especially when your a one man show ?
Danny
Which tachometer does it have?  I had a 78 model 886 once with the narrow steps yet.  The tachometer in mine was the digital readout style with a rotating knob rather than the touch buttons that my 79 1086 had.  Lots of subtle and not so subtle changes in the 86 model run!  I put a six pad 986 clutch in mine when the pto splines wore out.  Beautiful tractor!
It has the round mechanical driven tach , now I will have to check that number again so I can check it .
‘Danny
I think my 886 was in the 13,000 serial range.  Wonder if the steps on that one were changed......the wide ones were a lot safer.
Here is his 1486 planting tractor that’s all original ?? He takes really good care of his stuff as you can see ?
‘Danny
  • Like 9
Wow those are real nice 86’s an 886 would be something awesome to use with my IH #9 hay rake
He would like me to put a turbo on the 886 this summer not to go plowing with it just so it has a little air pressure in the manifold . His dad has a tractor just like it back in the day and they sold it on the retirement auction and they had a turbo on it and it gained 20 hp and really cleaned things up as a chore tractor . I told him , no problem , I’m your man pressurizing manifolds ?
I have always liked those D 360 motors and have been around them since they were new and there just the best little brother to the 400 series ??
806 man , that side of the bolt bid is the wall of shame , We don’t call it the Proving Grounds for nothing ?  I proved that you don’t put a 450 head /oversized in the injection pump , bigger lines and injectors and try running the stock turbo . Take it for a quick test drive down on the road , throws he TA a head in road gear and there goes the Solar out into the corn field , lucky it didn’t go in the motor !!
‘Danny
  • Confused 1
