Need 66 series dash/steering column help
redturbo
   I took the steering column out of the tractor to clean up from the leaking steering hand pump.  Got from the clutch housing to hitch clean up pretty good with varsol now.
   But when I lifted it out the door of the cab this spacer fell out on the floor.  Holy cow is that column heavy!  Here couple pictures of the spacer/bushing.  It’s 3/8” thick,  1 1/2” wide with a 3/4” hole.  I looked thru the parts book couple times & dont see it.  Any idea where it goes would be great,  thanks.
   Thanks,  I had tried it there but it didn’t just fit right.  Once I took the gauges out to wash it.  Could see my issue,  for some reason the spline shaft moved towards the center of the dash.  Which didn’t allow room for the spacer.  My first time working on a 66 series.  Have only been around a 100 Hydro as kid that neighbor has & this 766.
