Axle housing seals
fbh31118
Are you referring to the outer axle shaft seals ? I was getting them from Case-IH parts still last I checked there's a felt seal and lip seal if its simliar to a super M
Nope.  Axle carrier to rear end case.  The big 'sea shell' looking gasket.  Thanks for the help.
I call that a gasket then never seen to many of them leak but anything is possible I've never had to purchase one but those would be easy to make if you want too
If you got time, make your own out of gasket material.
I have made gaskets out of cereal boxes.
All are a paper product that just fills the voids between the two mating surfaces.
Places like mcmaster have  a large range of gasket materials.  With a set of gasket/paper hole punches, a some sharp instruments  and a little work you can make some good looking and fitting gaskets.
Harborfreight has a set made from soft material for less than $10.  Use them on a piece of wood a they will last so-so.
AND if you want a near perfect gasket us  SPELLMACO BLIND HOLE SPOTTERs from mcmaster to locate the exact location of the holes in the  casting. Machinists use them to mark a copy of holes an existing casting. Think of them as a center punch that fits in the center of an existing hole to mark that center on a new part.
6 minutes ago, fbh31118 said:
They weren't open today but I'll give it a try.
they are always open online are you in a big toot to get  a gasket? Case IH dealer will be open tomorrow I'm sure
