boots Posted January 20, 2021 Share Posted January 20, 2021 As above hear the board discussion this like quite often especially 66 series why is this wrong correct police or really something else ? Boots Link to comment Share on other sites More sharing options...
Mr. Brookville Posted January 20, 2021 Share Posted January 20, 2021 Any hose, Including steel braided hydraulic hose, Has a rating for the liquids and the pressures it will withstand. Easy to check in todays world. Must say rated for fuel oils. Link to comment Share on other sites More sharing options...
ole 815 Posted January 20, 2021 Share Posted January 20, 2021 Hose on the 66 and 86 series, and combines with same setup, hose needs to be able to pulse. It is easier on the head in pump and the housing. Hydraulic hose that is steel braided doesn't allow it act as the appropriate hose. Will it work, yep, and some will last for years with a hydraulic hose and not seem to affect anything. And some go bad with the correct hose. Jus use the correct hose. My 2cents Link to comment Share on other sites More sharing options...
snoshoe Posted January 20, 2021 Share Posted January 20, 2021 Yes it is the pulse. If the line does not have enough elasticity. The pump will actually starve for fuel because when the plunger should be filling. The fuel is actually moving in the other direction. The correct hose acts as an expansion chamber. So instead of a long column of fuel changing direction with every stroke. It's just a small volume next to the pump. The correct hose is actually hydraulic. R6 I believe could be wrong though. Link to comment Share on other sites More sharing options...
boots Posted January 21, 2021 Author Share Posted January 21, 2021 Thanks for the replies thought there must be a reason just did not know why thanks boots Link to comment Share on other sites More sharing options...
B.B. Posted January 21, 2021 Share Posted January 21, 2021 On 1/20/2021 at 12:58 PM, boots said: As above hear the board discussion this like quite often especially 66 series why is this wrong correct police or really something else ? Boots Thanks for asking I needed to know this too! Link to comment Share on other sites More sharing options...
hippy5488 Posted January 21, 2021 Share Posted January 21, 2021 as stated above it almost acts like a shock absorber for the pump. also have seen 10 hp. raise on the dyno with correct line versus hyd. hose. but that was only tractor i tried it on Link to comment Share on other sites More sharing options...
Missouri Mule Posted January 21, 2021 Share Posted January 21, 2021 I've always heard it referred to as harmonics. I have 100% seen a 966 that didn't run correct with hydraulic hose. The guy said he blew a hose and replaced it and now it felt like he still had air in it. When I asked which hose he told me, and I said oh where did you get it at? He said napa made it, and I said try again. He later told me it corrected the issue. Link to comment Share on other sites More sharing options...
