Rosebud advice needed
1586 Jeff
I have been having trouble with the rosebud head on my torch popping.  A LOT!!!  My neighbors must think that I am playing with firecrackers.  I never used to have trouble with my rosebud until a couple of years ago.  I have tried cleaning it with a torch tip cleaner, but it still pops.  If I back away from the workpiece it will stop popping, but no heat is being applied.
 I am looking for suggestions on how to fix this.
 Thank you!
Turn up the pressure on your fuel gas is the normal fix, but maybe I am missing something
I do not know them fix but i have had to send them out before,  they come back working i don’t complain. What brand? Smiths have some dodad in there that can become damaged and need repairs.
You have too big of a tip for your tank . Ours does the same thing. I just watched a video on torch operation last night that went over this
Around the 34 minute mark he talks about the rosebud
Or I am running out of acetylene?
The tank is low on gas AND I have a kinked hose that I noticed when I was taking the regulators of to put them away.
What size are your tanks?
Check to o rings at the base of the rosebud where you screw it into the torch head. If one of these is damaged you will get a lot of popping and very little heat.
Gas pressure to low
Regulator not large enough ( won't flow enough)
Hose too small for the needed flow
O-rings bad where the rose bud screws on the torch body
tip on the rose bud loose.
Make sure you have the correct tip for the fuel gas, I have seen people make that mistake  and as AK said your fuel PSI needs to be up  but don't go above 15 stay out of the red zone
A little safety here. Most people do not understand the 15 psi rule on acetylene. If you need more gas when you reach 15 it is time for changes of your equipment as  there can be dangerous  unwanted explosion. Was setting up a cutting station at a high school and had to get a manifold set up with multiple tanks and proper sized piping.  Also the separation of the acetone and acetylene does not happen correctly as you "bleed" it out of solution.
I think that is what the tank size is talked about on the video I posted
We had all the same problems with our rosebud.  Bought bigger hoses didn’t help.  Was told to manifold two acetylene cylinders together with a high flow regulator.  At the time our sales rep for the welding store was a very sharp guy.  He set us up with propelyne torch with a big heating tip.  That thing works great and puts out more heat than any rosebud I have ever touched and is easy to use.  The propelyne lasts longer than acetylene.  You can cut with it also but I have never had time to try it out.  IMHO if you can’t get your rosebud to work with minimal expense check into this.  It didn’t cost that much for the regulators and handle.  I got it from Haun welding.  I think there is one of those up your way.
There is a Haun Welding store as well as an Airgas store nearby.
However, the rosebud always USED TO WORK with my hoses, tanks, and regulators.
 I have checked and the o rings are toast on the rosebud attachment where it connects to the torch handle as well as the acetylene hose has some signs of being kinked where it takes off from the regulator.
Are the o rings specific to a torch or will generic o rings suffice?
Check to see if the butt has been dropped and there is a ding or high spot or oval shape on the female taper. Similar to what an o-ring failure on the torch will cause, but new o-rings won't fix this. Running out of gas or not enough pressure would have been my first guess but you said it used to run good and now it doesn't.
I often have to replace orings, I just use generic ones from my kit. They crack periodically, but i have seen no signs of strange deterioration.
3 hours ago, SMOKER 1 said:
Mine, the tip is loose.  How can that be fixed?
jerry
Victor torch? Depends on the size and gas. Loose at the base where the brass male taper meets the shaft? Just screw it back in. Some of the big propane rosebuds you can buy a new head but they are spendy. I think acetylene rosebuds have a silver soldered head.
