Need 1 pc rims for 1967 1200b
1200bdave
What is wrong with the two piece? I have the original two piece rims on my 1200A and have had no problems. Running radial tires and tubes for radial tires.
  • 4 weeks later...
I run splits on my 1200 c series trucks, they work fine for me. As far as different hubs, the 8lug hub off of a D series axle should work. I say should because I have not tried this or even compared beating numbers, etc. The hubs from early to mid 70’s F250’s might also be a possibility. I know this is a good interchange for brake parts, but again have never did the hub research, just a place to look. As far as the front goes, early closed knuckle D series stuff should work.
