756puller 31 Posted January 11 Share Posted January 11 Got a neighbor back home that has a 2wd 5488 with 9500 hrs on it. It's been sitting ten years in a shed. Has full rack of hundred pound weights and suppose to have a set of duals someplace for it. It's a 4 out of ten in condition of say. Bleed fuel system and it fired right up and idles good. Front end is loose as a goose. Did check for coolant in oil pan and there wasn't any. What's a fair price for it? 2 Quote Link to post Share on other sites
ksfarmdude 570 Posted January 11 Share Posted January 11 21 minutes ago, 756puller said: Got a neighbor back home that has a 2wd 5488 with 9500 hrs on it. It's been sitting ten years in a shed. Has full rack of hundred pound weights and suppose to have a set of duals someplace for it. It's a 4 out of ten in condition of say. Bleed fuel system and it fired right up and idles good. Front end is loose as a goose. Did check for coolant in oil pan and there wasn't any. What's a fair price for it? Any work done to it in its life ? tires look good from what I can see tractors like that are nearing major repairs too I would low ball a bid on price taking future repair costs into consideration around here they bring anywhere from 15 to 20 and that's if they average Quote Link to post Share on other sites
756puller 31 Posted January 11 Author Share Posted January 11 Guy just bought it to plant since his 5288 was getting overhauled than he backed out on the shed and there it has sat since 2010. Don't know of any major issues with it but with the engine sitting not getting the coolant circulated I'm sure it's just a matter of time before the liner prongs let loose. Quote Link to post Share on other sites
Farmall1066 2,067 Posted January 11 Share Posted January 11 Square front axle I see!!! If that’s loose, that might get costly because there weren’t many of those around, so parts will be limited, and every square axle I’ve looked into getting for our 5488, they all say it needs a bunch of work?! I’ve seen anything from $8500 on up for a 52-5488 sell that needs work. 1 Quote Link to post Share on other sites
Thesd5488 376 Posted January 11 Share Posted January 11 5-7500 Quote Link to post Share on other sites
Rick G. 259 Posted January 11 Share Posted January 11 Wow what a find. Looks like a good candidate to rebuild and refurbish. Offer $7,500.00 and go from there, but what do I know. Why do so many of those 50’ (or ‘88) series tractors always have their front grills missing???? What is up with that? Did they fall out easily and get plowed under or what? I’ve never been around that series much at all. I swear every dam one of those series I’ve seen down here in TX (not many) but still every one, has its front grill missing and they are beat to crap in general on top of that. Quote Link to post Share on other sites
1480x3 455 Posted January 11 Share Posted January 11 2 hours ago, Rick G. said: Wow what a find. Looks like a good candidate to rebuild and refurbish. Offer $7,500.00 and go from there, but what do I know. Why do so many of those 50’ (or ‘88) series tractors always have their front grills missing???? What is up with that? Did they fall out easily and get plowed under or what? I’ve never been around that series much at all. I swear every dam one of those series I’ve seen down here in TX (not many) but still every one, has its front grill missing and they are beat to crap in general on top of that. Is the grill missing ? Looks like it's there to me Quote Link to post Share on other sites
FarmallFan 1,024 Posted January 11 Share Posted January 11 1 hour ago, 1480x3 said: Is the grill missing ? Looks like it's there to me It looks to be there to me too. I think the image is overexposed due to low light and using flash. Quote Link to post Share on other sites
Reichow7120 1,962 Posted January 11 Share Posted January 11 1 minute ago, FarmallFan said: It looks to be there to me too. I think the image is overexposed due to low light and using flash. Yeah, its there. If you look closely, the IH emblem is in the lower right corner of the grill in the pic. If the grille screen was gone, the emblem wouldn't be there. Quote Link to post Share on other sites
snoshoe 536 Posted January 11 Share Posted January 11 The ih badge is there so I assume the screen its fastened to is there too. Although I can't see it. Quote Link to post Share on other sites
TP from Central PA 3,417 Posted January 11 Share Posted January 11 How many remotes? Single shaft PTO or someone retro a twin shaft in it? For me that front end makes it worth more. Also do the weights go with it? Why has it sat 10 years? Quote Link to post Share on other sites
756puller 31 Posted January 11 Author Share Posted January 11 It has the large pto shaft. Has 3 remotes. It has the grill it's just covered by an extra window screen. It has sat cause he bought it to plant with one season as his 5288 was getting the motor overhauled. It should include the front end weights and duals. Quote Link to post Share on other sites
WESnIL 205 Posted January 11 Share Posted January 11 Give her a good bath and it will look like a completely different tractor. 1 Quote Link to post Share on other sites
bkorth 336 Posted January 11 Share Posted January 11 Isn't that the same axle used on the Magnums, I've got a 7110 with over 10k hours and it's still tight, just needs a grease gun regularly like anything else. Quote Link to post Share on other sites
88power 1,613 Posted January 11 Share Posted January 11 5-7500 seen one similar sell down here quick like that for around the same money in the fall, and like its been said those front ends can get costly fixing Quote Link to post Share on other sites
Farmall1066 2,067 Posted January 11 Share Posted January 11 4 hours ago, bkorth said: Isn't that the same axle used on the Magnums, I've got a 7110 with over 10k hours and it's still tight, just needs a grease gun regularly like anything else. I don’t believe they are the same?! I know if going from a round front axle, to the square, you have to swap the lower front bolster as well. Quote Link to post Share on other sites
bitty 6,097 Posted January 12 Share Posted January 12 5 hours ago, bkorth said: Isn't that the same axle used on the Magnums, I've got a 7110 with over 10k hours and it's still tight, just needs a grease gun regularly like anything else. I am guessing that the front bolster is different from the Magnum as they are different on the 4x4 Magnum to 5x88 1 Quote Link to post Share on other sites
89vmax 21 Posted January 12 Share Posted January 12 Np getting parts for front axle send axle to have it line bored if needed a and I has the pins bushings tie rods its not a bad job Quote Link to post Share on other sites
neukm 7 Posted January 12 Share Posted January 12 If that tractor has had the speed transmission updates, it's worth a lot more than 7500 Quote Link to post Share on other sites
stronger800 1,014 Posted January 12 Share Posted January 12 Like 10k more, if it was here in NY anyway 1 Quote Link to post Share on other sites
Matt Kirsch 1,008 Posted January 12 Share Posted January 12 1 hour ago, stronger800 said: Like 10k more, if it was here in NY anyway Point a hose at it and it's a solid $15K tractor around here if it runs and drives. Probably more than that. Quote Link to post Share on other sites
756puller 31 Posted January 12 Author Share Posted January 12 I'm betting nothing has been done to it for updates. It was traded in to the ih dealer in columbus, my neighbor needed something quick and cheap and that's what he found. Got done planting and put it in the shed after that. Quote Link to post Share on other sites
neukm 7 Posted January 12 Share Posted January 12 29 minutes ago, 756puller said: I'm betting nothing has been done to it for updates. It was traded in to the ih dealer in columbus, my neighbor needed something quick and cheap and that's what he found. Got done planting and put it in the shed after that. A 5488 with 9500 hours has almost certainly had the speed transmission opened up. The question would be, did they update the countershaft at the time to the keyed vs the spline. Quote Link to post Share on other sites
756puller 31 Posted January 12 Author Share Posted January 12 Up around my area it's hard to say, people don't fix it til it's broke and they usually only fix the bare minimum. Quote Link to post Share on other sites
J-Mech 1,489 Posted January 12 Share Posted January 12 $5,000 Quote Link to post Share on other sites
