pirlbeck Posted January 10, 2021 Share Posted January 10, 2021 I am making a new fuel line from the tank shut off valve to the fuel filter inlet for my 1456 and would like to see a few shots of the factory line if anyone would have one available. My line has been cut off and a hose installed part way in-between, but the front part that is left don't look like it is shaped correctly. I looked it up on the parts listing and the picture they have drawn is not a lot of help either. They do not list a part number of the OEM line, but I would guess a 1256 would be the same. Here is a picture of what I have on the tractor now. I don't think the 90 bend on the filter base end is correct for this line or I would copy the parts of the line I have and just build it with the same shape I have on the ends and just guess on the shape of the missing part. Thanks! Link to comment Share on other sites More sharing options...
TP from Central PA Posted January 10, 2021 Share Posted January 10, 2021 Mine has kind of a s-bend to it..........Not sure if that is right or not, but what is on mine. Will grab a picture later today(Someone may beat me to it though). Link to comment Share on other sites More sharing options...
pirlbeck Posted January 10, 2021 Author Share Posted January 10, 2021 12 minutes ago, TP from Central PA said: Mine has kind of a s-bend to it..........Not sure if that is right or not, but what is on mine. Will grab a picture later today(Someone may beat me to it though). Although my picture does not show it very well, this one has a pretty tight 180 bend back at the shut off bend, which I think is correct. I don't think an S bend would be needed to get it routed, but they may of made it that way for vibration and resistance to cracking. A picture would be a great help. Thanks for your reply! Link to comment Share on other sites More sharing options...
SDman Posted January 10, 2021 Share Posted January 10, 2021 From the parts book....don't look like it was ever offered through the parts system as a replacement part. It tells you to use a 22" chunk of 3/8" tubing and a couple inverted flare nuts and make it accordingly. Link to comment Share on other sites More sharing options...
pete23 Posted January 10, 2021 Share Posted January 10, 2021 We always made fuel lines, gasoline lines from bulk roll as instructed in parts manual. Letter series up through 86 series except the hose from filter to pump on the diesels where used. Link to comment Share on other sites More sharing options...
TP from Central PA Posted January 10, 2021 Share Posted January 10, 2021 I forgot while doing chores, Its out sitting in mother natures shed in the barn lot(Waiting on parts for the starter). This is what was on it as long as I had it, whether its right or not is for debate. And yes, the temp probe isn't right, but not messing with that until it is rebuilt Link to comment Share on other sites More sharing options...
pirlbeck Posted January 11, 2021 Author Share Posted January 11, 2021 That makes perfect sense given what I have left of the OEM line still on there. Maybe there was a reason IH felt they needed to keep it tucked in under the fuel tank directly to the rear of the engine. But I can't think of any attachment/option that it could interfere with. Or maybe it was to lessen the chance of vibration or cracking as I mentioned above. Anyway thanks a bunch...that is exactly what I needed to finish fabricating one. Link to comment Share on other sites More sharing options...
TP from Central PA Posted January 11, 2021 Share Posted January 11, 2021 Don't know, just know that is on the one here, maybe Long Farms will see this and know what should be right. This one looks factory when I have had it off over the years. Link to comment Share on other sites More sharing options...
Haywire Posted January 11, 2021 Share Posted January 11, 2021 One owner 1970 1456 Link to comment Share on other sites More sharing options...
Haywire Posted January 11, 2021 Share Posted January 11, 2021 Also have a 1970 1026 in the shop. Similar setup but that line is different Link to comment Share on other sites More sharing options...
DT Fan Posted January 11, 2021 Share Posted January 11, 2021 Haywire, welcome to the forum! Nice way to break in. Link to comment Share on other sites More sharing options...
TP from Central PA Posted January 11, 2021 Share Posted January 11, 2021 Haywire that 1026 line looks just like mine. Link to comment Share on other sites More sharing options...
pirlbeck Posted January 11, 2021 Author Share Posted January 11, 2021 Haywire, Thanks for the help! Link to comment Share on other sites More sharing options...
pirlbeck Posted January 11, 2021 Author Share Posted January 11, 2021 3 minutes ago, TP from Central PA said: Haywire that 1026 line looks just like mine. I agree that the basic shape of the line looks very similar, but the routing is different. I THINK the the routing of TP's line looks more "correct" then Haywires. Link to comment Share on other sites More sharing options...
nate Posted January 11, 2021 Share Posted January 11, 2021 2 hours ago, Haywire said: One owner 1970 1456 Sorry to derail thread, But we need pics of the whole 14 with front scratch!! Link to comment Share on other sites More sharing options...
Long Farms Posted January 11, 2021 Share Posted January 11, 2021 Every one of my 407 engines except ones with factory installed belly tank have the same line. Belly tank style has bleeder before filter. An 856 CUSTOM might have a different line since it has 37 gal fuel tank. Link to comment Share on other sites More sharing options...
Haywire Posted January 11, 2021 Share Posted January 11, 2021 1 hour ago, nate said: Sorry to derail thread, But we need pics of the whole 14 with front scratch!! Link to comment Share on other sites More sharing options...
pirlbeck Posted January 12, 2021 Author Share Posted January 12, 2021 5 hours ago, Long Farms said: Every one of my 407 engines except ones with factory installed belly tank have the same line. Belly tank style has bleeder before filter. An 856 CUSTOM might have a different line since it has 37 gal fuel tank. Thanks Long, those pictures will help a bunch. Link to comment Share on other sites More sharing options...
acem Posted January 12, 2021 Share Posted January 12, 2021 I think those might be the same lines installed in a different rotation. My 1456 had a rubber line. Thx-Ace Link to comment Share on other sites More sharing options...
nate Posted January 12, 2021 Share Posted January 12, 2021 7 hours ago, Haywire said: Looks tough! Is it a demo?? Link to comment Share on other sites More sharing options...
Haywire Posted January 12, 2021 Share Posted January 12, 2021 8 hours ago, nate said: Looks tough! Is it a demo?? Yes Link to comment Share on other sites More sharing options...
pirlbeck Posted January 12, 2021 Author Share Posted January 12, 2021 9 hours ago, acem said: I think those might be the same lines installed in a different rotation. My 1456 had a rubber line. Thx-Ace Yes, I think you are correct. It seems like these lines get bent, modified and screwed up all to often, mostly from sloppy workmanship. Link to comment Share on other sites More sharing options...
pirlbeck Posted January 12, 2021 Author Share Posted January 12, 2021 Thanks Long, those pictures are a big help! Link to comment Share on other sites More sharing options...
pirlbeck Posted January 17, 2021 Author Share Posted January 17, 2021 I got a new line fabricated and installed. While it may not be perfect I think it is close enough. Thanks to everyone for the help! Link to comment Share on other sites More sharing options...
INTERNATIONAL 1466 Posted January 17, 2021 Share Posted January 17, 2021 Looks pretty good! Link to comment Share on other sites More sharing options...
