Dt466 Lower water neck housing
Flatbedcowboy
Hello,
I am need of a part number for the lower waterneck housing on the passenger side front of a DT466. Its the part that connects the lower coolant rubber line from the engine to the radiator, its a cast piece that also has a bung hole for the heater line.
Mine is a 90* pointing down, and I want one that points out straight at the radiator. I think my engine is a late 1980s model since it has the MW injection pump.
Thank you
