1450 Electrical problems
Red Flyer
I have a good starter, good relay and good switch. I have power to both sides of the amp meter but my switch seems to be dead. Is it possible the voltage regulator is my problem?
Thanks in advance.
APF
Switches regularly go bad, also check for a bad safety switch (PTO often a culprit) as they are interconnected.
Try a jumper wire from the "start" post on the key switch and the solenoid trigger post......if its a safety interlock issue, this will bypass it temporarily.
VR us not the issue.
Try holding the key switch in the "start" position and wiggling the pto switch. Often times on Quietlines the pto switch will be just barely engaged and it will act as if you have a dead battery or a bad neutral start safety switch. Have had several here that have done this. Just a thought. If that works, replace the pto switch.
