Joninva Posted December 25, 2020 Share Posted December 25, 2020 Anybody know if a rollbar off a 686 will fit a farmall 504? Quote Link to comment Share on other sites More sharing options...
ksfarmdude Posted December 25, 2020 Share Posted December 25, 2020 2 minutes ago, Joninva said: Anybody know if a rollbar off a 686 will fit a farmall 504? What type & brand of rollbar you talking about factory IH ? I'm sure with modifications it will the axle housing size and width would be the first things I'd check Quote Link to comment Share on other sites More sharing options...
nepoweshiekfarmalls Posted December 26, 2020 Share Posted December 26, 2020 I have seen a 666 2 post roll gard on a Farmall 504. Quote Link to comment Share on other sites More sharing options...
Joninva Posted December 26, 2020 Author Share Posted December 26, 2020 Its factory IH Quote Link to comment Share on other sites More sharing options...
Matt Kirsch Posted December 26, 2020 Share Posted December 26, 2020 I believe it will fit, as the 504 is built off a 460 rear end, and the 686 is externally the same dimensions as a 460 rear end. Both have the square axle housings. Quote Link to comment Share on other sites More sharing options...
Jeff-C-IL Posted December 26, 2020 Share Posted December 26, 2020 Pretty sure the 500 series and the 600 series use the same basic rear end. IIRC, are really only 2 rear axles in the "row crop" line - the square axle the older &small frame tractors had up thru the 686, and the hex axle that the 806 & up larger tractors used. Quote Link to comment Share on other sites More sharing options...
Ed Leaman Posted December 27, 2020 Share Posted December 27, 2020 On 12/25/2020 at 12:31 PM, Joninva said: Anybody know if a rollbar off a 686 will fit a farmall 504? yes it will. Quote Link to comment Share on other sites More sharing options...
Joninva Posted December 30, 2020 Author Share Posted December 30, 2020 Thanks y'all Quote Link to comment Share on other sites More sharing options...
