François02 Posted December 11, 2020 Share Posted December 11, 2020 Hello everyone I created a topic few years ago but lot of pics disappeared... here it is: I still restore the tractor... I need more time to work on it and few parts were hard to arrive here because I didn't work with the good guy... But now I have almost all parts I need. 2 Quote Link to comment Share on other sites More sharing options...
François02 Posted December 11, 2020 Author Share Posted December 11, 2020 I have a question because I had to change the hitch levers support and I lost a part on the hitch distributor... ? The hitch distributor is leaking so I will change the seal between it and the trans cover. But can I have all distributors by remove the 3 bolts I put in yellow on the pic? There is 2 rods for the hitch and I hope it will stay here what do you think? thanks for your replies Quote Link to comment Share on other sites More sharing options...
François02 Posted December 16, 2020 Author Share Posted December 16, 2020 Finally the part I losted was in the gearbox, easier to take with a magnet. About brakes, what do you think of mine? Do you know the thickness of a disc when it is new? Quote Link to comment Share on other sites More sharing options...
François02 Posted December 20, 2020 Author Share Posted December 20, 2020 Not a lot of replies but perhaps I will find help with this one! The hitch levers support had been broken and welded... sadly it was wrong welded. I had to change it and I found one but mine is with a spinnaker seal and a bushing (brass I guess). The support I have to replace has not that assembly, there is plastic bushing and that's all... (and O-rings) What do you think? O-ring + plastic bushing are enough to be sure there won't be a leak? Quote Link to comment Share on other sites More sharing options...
snoshoe Posted December 20, 2020 Share Posted December 20, 2020 Sorry. First picture I'm sure you know by now the answer was yes. The brakes look good to me. As long as the hubs have clearance I would use them. Have no idea what specs would be. As far as the plastic bushing and oring. I have no memory of any thing else. Quote Link to comment Share on other sites More sharing options...
François02 Posted December 20, 2020 Author Share Posted December 20, 2020 I do some research on NGPC (parts online) and there was 2 mounting... sadly the view on NGPC is really really blurry I will check tomorrow on the workshop I will have to change O-rings at least, bushing I will check if there is some play Quote Link to comment Share on other sites More sharing options...
François02 Posted December 21, 2020 Author Share Posted December 21, 2020 After a long time to search, I found what I was searching there is some plastic bushing, my dealer can have only 1 ref but it is OK because they are not ruined. I will change 2 of them because it is not expensive (4€ each) and while all is dismantle, it is the opportunity! But I have a doubt about a part... It is a little bearing, ref #532408R1 (in yellow in my pic) If someone knows dimensions of it... I don't know if mine is ruined or if it good, and I didn't found any dimensions on the Internet... Thanks in advance! Quote Link to comment Share on other sites More sharing options...
François02 Posted December 21, 2020 Author Share Posted December 21, 2020 And I guess the hardness of the levers is settled when I squeeze the bolt on it? In the original assembly there is a spring with frictions washers Quote Link to comment Share on other sites More sharing options...
snoshoe Posted December 21, 2020 Share Posted December 21, 2020 I am slow to remember. The plastic bushing and clamp I remember as a 66 series thing. Easier to adjust but just as suseptible to corrosion Quote Link to comment Share on other sites More sharing options...
mmi Posted December 22, 2020 Share Posted December 22, 2020 the brakes for USA 52-66' are + - 1/2" .50 us NEW and done when 7/16" .437 us not sure after '65 there are 8 wearing surfaces to brake pack so .45 or less may not hold good and <.43 could be none or over center and lock this says they are < 7/16 NEW 17DISC- DISC,46.63mm ID x 203.2mm OD x 11.1mm Thk 84468308 Quote Link to comment Share on other sites More sharing options...
François02 Posted April 13, 2021 Author Share Posted April 13, 2021 Hello guys I'm looking for paint for my 756 What is the good (or better) RAL for a 1970's farmall? The compagny where I will take the paint can't mix two RAL For red, and white and silver (rear rims) Do you paint the exhaust manifold with a high temperature paint? what color do you use (I can choose between black and grey (silver))? and last question, how much paint will I need? A compagny can provide me PPG paint. I know you use this brand in the US, so what references do you use? Thanks a lot for your help! Quote Link to comment Share on other sites More sharing options...
TeachersPet1066 Posted April 14, 2021 Share Posted April 14, 2021 16 hours ago, François02 said: Do you paint the exhaust manifold with a high temperature paint? https://www.tptools.com/SEYMOUR-High-Temp-Cast-Blast-Restoration-Paint-12-oz,6694.html?b=s*seymour+cast+blast+restoration+paint%2c+12+oz A restoration pro told me about this cast blast and I tried it and really like it compared to other high temp black paints. 4 Quote Link to comment Share on other sites More sharing options...
TeachersPet1066 Posted April 14, 2021 Share Posted April 14, 2021 16 hours ago, François02 said: A compagny can provide me PPG paint. I know you use this brand in the US, so what references do you use? I had some issues with the 901 white last year but finally was able to get it made. Quote Link to comment Share on other sites More sharing options...
François02 Posted April 14, 2021 Author Share Posted April 14, 2021 11 hours ago, TeachersPet1066 said: https://www.tptools.com/SEYMOUR-High-Temp-Cast-Blast-Restoration-Paint-12-oz,6694.html?b=s*seymour+cast+blast+restoration+paint%2c+12+oz A restoration pro told me about this cast blast and I tried it and really like it compared to other high temp black paints. I don't find it here ? I will keep searching... It looks really nice, almost as a new part! Quote Link to comment Share on other sites More sharing options...
François02 Posted April 14, 2021 Author Share Posted April 14, 2021 Thanks for the colors but if someone knows RAL... about red 3003 seems too dark and 3002 seems too clear, a mix between both isn't possible where I can have good quality paint (it is a paint maker, with prices 2 or 3 times cheappers than PPG, for the same quality) Quote Link to comment Share on other sites More sharing options...
1066 Peterbilt Posted April 19, 2021 Share Posted April 19, 2021 I am a gallon in right now and have not touched the wheels or hubs. Thanking two gallons will catch it. Maybe a gallon and three quarts but that would probably cost more than two gallons. Do some research on that paint. Red is a hard keeper and I regret saving money in the past. Looks good thanks for sharing. 1 Quote Link to comment Share on other sites More sharing options...
acem Posted April 19, 2021 Share Posted April 19, 2021 If you post your questions in a general ih forum you will get more replies. There are even a few French speakers on there to help with translations. BTW my family name is French. Martin 'Ace' Mershon Originally Marchand Quote Link to comment Share on other sites More sharing options...
1066 Peterbilt Posted April 20, 2021 Share Posted April 20, 2021 On 4/14/2021 at 7:58 AM, François02 said: Thanks for the colors but if someone knows RAL... about red 3003 seems too dark and 3002 seems too clear, a mix between both isn't possible where I can have good quality paint (it is a paint maker, with prices 2 or 3 times cheappers than PPG, for the same quality) Then maybe buy equal amounts if it is good paint and mix them 50/50. Use hardner. We are going to work not the parade and our paint deal is a little quick. Some of it is hot water pressure washed with degreaser. Then spray it down with aluminum bright ( acid ) and let it dry. That etches the old paint and pressure wash it again. If you use sealer you can paint over shortly after spraying it that will cut down on the amount of color paint you have to use. I did not do that taking my short cuts. Will not have any gray showing up if it flakes off. Will take more time doing the sheet metal. It stinks when you save a little money on paint and have a pink tractor 4 years later. Spraying Martin Senior this time. I thank it's good. Have to drive an hour for PPG but Napa delivers the other. Quote Link to comment Share on other sites More sharing options...
François02 Posted April 21, 2021 Author Share Posted April 21, 2021 thanks for your replies I have some informations which tells about 2 gallons. In my case everything is dimantle and I will paint each part one by one, which will ask more paint I guess. But 2 gal is a good start! I will use an epoxy primer (with zinc in it againt rust) and a polyuréthane paint. Both with hardner. What color do you use in primer? white or grey? About brakes... I find kits to change all brakes but there is spings in the kit and I don't remember to have dismantle springs. Perhaps there was differents mounting? Quote Link to comment Share on other sites More sharing options...
VacDaddyt Posted April 21, 2021 Share Posted April 21, 2021 Red primer, did one with grey and the paint came out a wine type color. Beautiful but not expected. 1 Quote Link to comment Share on other sites More sharing options...
1066 Peterbilt Posted June 22, 2021 Share Posted June 22, 2021 On 4/21/2021 at 5:03 AM, François02 said: thanks for your replies I have some informations which tells about 2 gallons. In my case everything is dimantle and I will paint each part one by one, which will ask more paint I guess. But 2 gal is a good start! I will use an epoxy primer (with zinc in it againt rust) and a polyuréthane paint. Both with hardner. What color do you use in primer? white or grey? About brakes... I find kits to change all brakes but there is spings in the kit and I don't remember to have dismantle springs. Perhaps there was differents mounting? Last time the fenders were gray lacquer, the paint was pretty good. The hood was sanded to bare metal and a brown rust-Oleum primer. The red all turned about the same color in a few years. Quote Link to comment Share on other sites More sharing options...
François02 Posted August 6, 2021 Author Share Posted August 6, 2021 I received the paint few month ago the primer is white/ clear grey I choosed the RAL3002 because I prefer clear red than dark red... It's my taste! I have some questions about tools... I own those tools: https://catalog.kingtony.eu/fr/2031-1216sr and https://catalog.kingtony.eu/fr/1647-4526sr04 But I always need a wrench which isn't into theses combinations... I can do the work with a metric wrench but I don't understand... Does it exist others wrenches dimensions than I have? Quote Link to comment Share on other sites More sharing options...
snoshoe Posted August 7, 2021 Share Posted August 7, 2021 As to your tool question. Engine and fuel system is german. So metric. Does that explain your problem? Quote Link to comment Share on other sites More sharing options...
François02 Posted August 7, 2021 Author Share Posted August 7, 2021 I have the same problem with my 7210 magnum: To dismantle the batteries box, 2 bolts with 5/8 wrench, 2 others were with 18mm wrench, not 11/16 or 1/4! Quote Link to comment Share on other sites More sharing options...
François02 Posted August 9, 2021 Author Share Posted August 9, 2021 About cooling system on my 756, I have to replace hoses. The one at the bottom is #396355R1 and according to the next website link it is the good one: https://www.messicks.com/part/396355r1/hose-radiator The other on the top should be #406766R1 but it exists the ref #396354R1 (if I understand correctly it is for tractors with serial number before 15185) My serial number is 17871 so do you confirm it is #406766R1? You can the a pic of the tractor to compare, I am talking about the yellow circle Thanks in advance for your help, those parts aren't frequent in Europe and I don't want to order for a wrong ref! The one in red is # 3132912R1; it looks right: https://www.messicks.com/part/3132912r1/hose Quote Link to comment Share on other sites More sharing options...
