1086 3 pt
gafarm49
tractor sat for 6 months and now to lift the 3 pt you lift lever and then lift draft lever. to get it to go down push lever down and then push draft lever down. any hints as to what to check qould be helpful. thanks
On 12/8/2020 at 3:59 PM, N S said:
Not on this same subject but related, does anyone know the lifting capacity of the 3 point on the 1086? I have been unable to find such even on tractordata.com
Its seems everywhere I have seen a "rating" its around 6,000 lbs
Here's a chart...
On 12/5/2020 at 2:44 PM, Sparky said:
Remove your centerlink cover and inspect your draft control linkage. I'd suspect that the linkage has slipped around to the wrong side.
Travis
I took the cover off and the linkage is right but there fluid pouring from the top
