hardtail Posted February 5, 2022 Share Posted February 5, 2022 Could but having been in this museum numerous times I'm guessing it will all be manual machining and that's not intended negatively 1 Quote Link to comment Share on other sites More sharing options...
Dirt_Floor_Poor Posted February 5, 2022 Share Posted February 5, 2022 This has to be the first new undercarriage parts for a T-6 that have been manufactured in a long time. 2 Quote Link to comment Share on other sites More sharing options...
Mogulman Posted February 5, 2022 Author Share Posted February 5, 2022 22 hours ago, mmi said: SOOOO can you spec them and just program CNC to pop them out? We could, but they are simple enough and will come out quickly on the old manual lathe and mill the museum has…only time is needed to do this there, no other expenses. 2 Quote Link to comment Share on other sites More sharing options...
just Dave Posted February 5, 2022 Share Posted February 5, 2022 1 hour ago, Mogulman said: We could, but they are simple enough and will come out quickly on the old manual lathe and mill the museum has…only time is needed to do this there, no other expenses. What alloy will you use. Do you have your own heat treat capability. Those deep lube holes in the end will be the pain in an engine lathe. We deep drilled many tons of pins in Warner Swasey turret lathes. You can't beat them for heavy stock removal also. They are cheap to pick up in this era of CNC . You know one would make a nice museum piece ......truly a landmark of industrial history. I hate to think how many have died an undignified death. 1 Quote Link to comment Share on other sites More sharing options...
Mogulman Posted February 5, 2022 Author Share Posted February 5, 2022 41 minutes ago, just Dave said: What alloy will you use. Do you have your own heat treat capability. Those deep lube holes in the end will be the pain in an engine lathe. We deep drilled many tons of pins in Warner Swasey turret lathes. You can't beat them for heavy stock removal also. They are cheap to pick up in this era of CNC . You know one would make a nice museum piece ......truly a landmark of industrial history. I hate to think how many have died an undignified death. We discussed this for a while. The metal will be a high grade steel. We could harden them, but we debated how much will it be used. It will never work every day again. It will maybe pull a small plow once a year. More likely less than that even. It will get driven 2-3 hours a year at most. None of us alive today will never need to replace them. The machining does not worry the machinist at all and he will have no trouble making these. He has made considerably tougher items in the past. He was originally planning on just grinding them...but when we started looking we realized how far he would have to go and the amount they would need to be ground (some of them we debated may even go smaller that the bushings we just put in), on top of having bad seal surfaces, it would be more efficient to make new ones. I am sure he will debate himself about the hardening in the process as he mentioned some of his options including nitrogen hardening them if he decides it is necessary. That is the next step...we will see where it goes. 1 1 Quote Link to comment Share on other sites More sharing options...
Rawleigh99 Posted February 7, 2022 Share Posted February 7, 2022 Get surface hardened ground stock of the right major diameter and machine with carbide tooling. Once you get the rind off they should machine easily. 1 Quote Link to comment Share on other sites More sharing options...
just Dave Posted February 7, 2022 Share Posted February 7, 2022 I have marveled at the quality of material and heat treat involved in my old IH tractors.... You as restorers have done amazing work on this machine with the prep and restoration of worn metal. You owe it to your selves to put a hard shaft in the rollers. Even a case hardening or a carburizing would be well worth while. On 2/5/2022 at 4:44 PM, Mogulman said: The machining does not worry the machinist at all and he will have no trouble making these. He has made considerably tougher items in the past. The small diameter deep hales are not difficult just a pain . If you have a moment to ask the Machinist, what alloy are you using? Thanks Dave 2 Quote Link to comment Share on other sites More sharing options...
Rawleigh99 Posted February 7, 2022 Share Posted February 7, 2022 You would need someone that did spray welding to save the originals. 2 Quote Link to comment Share on other sites More sharing options...
rusty iron Posted February 8, 2022 Share Posted February 8, 2022 Dont the original shafts have an oil cavity in the centre? Quote Link to comment Share on other sites More sharing options...
just Dave Posted February 9, 2022 Share Posted February 9, 2022 They are deep drilled from one end and cross drilled in two places . Spray weld /metalizing is big cost , it would require removing about a 1//4 off the diameter for prep. If they are the typical IH quality heat treated alloy that would be slow and hard on expensive lathe tooling. On a stubby shaft like that you could get by with 1045 and case hardening. If it was my tractor it would not look nearly as fabulous these men have done but it would not have soft feet.....I would take the existing shafts down to smooth via OD Grinder and make my bushings fit. I would accept some small pitting to remain of stock removal exceeded .100" per side. You could remove the stock with ceramic inserts but they are pricey. We will see how you do it I'm sure, Hat's of to your project. Dave 1 Quote Link to comment Share on other sites More sharing options...
Mogulman Posted February 19, 2022 Author Share Posted February 19, 2022 The new roller axles will be made from 4140 steel. Hardening is still being considered. 1 Quote Link to comment Share on other sites More sharing options...
Mogulman Posted April 8, 2022 Author Share Posted April 8, 2022 The shutters have been straightened and fitted. 1 Quote Link to comment Share on other sites More sharing options...
Mogulman Posted April 8, 2022 Author Share Posted April 8, 2022 The grill fits nice and is ready for final sanding. 1 Quote Link to comment Share on other sites More sharing options...
Mogulman Posted April 8, 2022 Author Share Posted April 8, 2022 Another update, the engine kit and all the roller seals have arrived as well. Soon more to come. 2 Quote Link to comment Share on other sites More sharing options...
Rawleigh99 Posted April 11, 2022 Share Posted April 11, 2022 You do exquisite work! 1 Quote Link to comment Share on other sites More sharing options...
Mogulman Posted May 27, 2022 Author Share Posted May 27, 2022 Parts for the engine are finally all here. Now it begins to go together. 2 Quote Link to comment Share on other sites More sharing options...
Mogulman Posted May 27, 2022 Author Share Posted May 27, 2022 While waiting for the final engine pieces, the governor was rebuilt. 2 Quote Link to comment Share on other sites More sharing options...
Mogulman Posted May 27, 2022 Author Share Posted May 27, 2022 The carburetor was also rebuilt during the wait as well. 3 Quote Link to comment Share on other sites More sharing options...
mmi Posted May 27, 2022 Share Posted May 27, 2022 how are those assm rebuilt ? in house/shop how do you confirm correct part/method nos parts (found where) made parts,or just handy china since it will have limited use Quote Link to comment Share on other sites More sharing options...
Mogulman Posted May 27, 2022 Author Share Posted May 27, 2022 3 hours ago, mmi said: how are those assm rebuilt ? in house/shop how do you confirm correct part/method nos parts (found where) made parts,or just handy china since it will have limited use The engine crank was sent out for grinding. All the other parts rebuilt in house. Parts are checked carefully and only rebuilt as necessary. Some NOS parts, always the best we can find. So far so good! 1 Quote Link to comment Share on other sites More sharing options...
Mogulman Posted June 9, 2022 Author Share Posted June 9, 2022 Sleeves are in, water pump and various other components are attached! 4 Quote Link to comment Share on other sites More sharing options...
hardtail Posted June 10, 2022 Share Posted June 10, 2022 Haven't seen water pump pulley threads that clean well like forever 1 Quote Link to comment Share on other sites More sharing options...
Mogulman Posted June 10, 2022 Author Share Posted June 10, 2022 5 hours ago, hardtail said: Haven't seen water pump pulley threads that clean well like forever That is probably because they are new. 1 Quote Link to comment Share on other sites More sharing options...
poor farmer/logger Posted June 14, 2022 Share Posted June 14, 2022 Thanks for keeping us updated. Enjoy following along. 1 Quote Link to comment Share on other sites More sharing options...
Mogulman Posted July 16, 2022 Author Share Posted July 16, 2022 Checking over the dash and electrical components to make sure there are no extra holes where they shouldn’t be. Waiting for the pistons and rods to come back from the engine shop since we needed new bushings. 5 Quote Link to comment Share on other sites More sharing options...
