1086 data center
ISP1086
8 minutes ago, ISP1086 said:
EGT and MPH work on data center but nothing else. Also fuel gauge always says full and coolant doesn’t work. Any ideas?
Check all the grounds
I already answered this on your facebook post...Anyway, since everything except the RPM works on the data center, trace the wires between the data center and rpm transducer. Test your RPM transducer if you can't find a problem in the wiring. Should be pretty easy... Also, once you get the RPM's to show, your pto speed will work, too. ?
Travis
