574 Cat I/II Lower 3PT Pin Dimensions
The small ends are cat 1 size. The larger center section is cat 2. The lower link had cat 1 on one end and 2 on other. The pin could be inserted either way to connect whichever end was needed. I can't help you with the length except that it should not too hard to measure. The holes in the housing are cat 1 on the inboard side and 2 on the outside.
