rodhergott 0 Posted November 20, 2020 Share Posted November 20, 2020 Seems like ripper for td15c is hard to find. Any chance that a cat ripper will bolt on to td15c Quote Link to post Share on other sites
nomorejohndeere 414 Posted November 20, 2020 Share Posted November 20, 2020 You can mount anything you want Quote Link to post Share on other sites
rodhergott 0 Posted November 20, 2020 Author Share Posted November 20, 2020 By bolt o n I meant easy fit No machining etc Quote Link to post Share on other sites
Kevingweq 180 Posted November 20, 2020 Share Posted November 20, 2020 7 minutes ago, rodhergott said: By bolt o n I meant easy fit No machining etc Kinda doubt the easy button will work 😀 Quote Link to post Share on other sites
rodhergott 0 Posted November 21, 2020 Author Share Posted November 21, 2020 If I was lucky enough to get one off a td15c I would think it would be bolt on. I’m wondering how much modification if I find one from a d5 or d6 Quote Link to post Share on other sites
ray54 763 Posted November 21, 2020 Share Posted November 21, 2020 My guess is it will, if from the same time. I know the TD 14 and and Cat D6 from the 50's had the same bolt patterns for winches and rear hydraulic pumps. Quote Link to post Share on other sites
rodhergott 0 Posted November 21, 2020 Author Share Posted November 21, 2020 Good to hear. I will measure bolt patters so I’m prepared Quote Link to post Share on other sites
louie figone 41 Posted November 21, 2020 Share Posted November 21, 2020 This is what you are looking for? Where are you located? They were used in the West probably more than the mid-west or east. The mounting plates (trunnions) I doubt will bolt up but you may be able to re-drill the holes to mount the trunnions. I would look for a tool bar carrier for a TD14 through the TD15 series, that would be the easiest way to go. I mounted the TD9B mounting plates on my TD6 by drilling new mounting holes on the plates. Call Associated tractor in Stockton CA, he may be able to help you. Quote Link to post Share on other sites
rodhergott 0 Posted November 21, 2020 Author Share Posted November 21, 2020 That’s a subsoiler rather than a ripper but now that I see it I could probably use one of those too. I was looking for a ripper to teal out roots left after logging Quote Link to post Share on other sites
DWF 51 Posted November 21, 2020 Share Posted November 21, 2020 About 20 years ago when I was looking for my first 15C I saw a couple of 15C's that had heavy duty rippers mounted on them. Maybe you could check junk yards, maybe one around yet. DWF Quote Link to post Share on other sites
rodhergott 0 Posted November 21, 2020 Author Share Posted November 21, 2020 Yes I’m trying that. Great music nds think alike Quote Link to post Share on other sites
louie figone 41 Posted November 21, 2020 Share Posted November 21, 2020 1 hour ago, rodhergott said: That’s a subsoiler rather than a ripper but now that I see it I could probably use one of those too. I was looking for a ripper to teal out roots left after logging Oh sorry, I misunderstood, you want a rear mounted ripper Quote Link to post Share on other sites
rodhergott 0 Posted November 21, 2020 Author Share Posted November 21, 2020 Yes rear mounted ripper Quote Link to post Share on other sites
pede 10 Posted November 21, 2020 Share Posted November 21, 2020 It should have a whole slue of drilled and tapped holes on the back plate, might take a little fab work but anything will fit. A lot of guy's use root rakes mounted to the blade. Quote Link to post Share on other sites
D6 Merv 1 Posted November 25, 2020 Share Posted November 25, 2020 Rear Stud patterns are different from a TD15B/C to a D6C/D. know this for a fact from winch bolt patterns. Spigot holes are exactly the same though. Cat rippers will fit only if you redrill the bolt holes 1 Quote Link to post Share on other sites
rodhergott 0 Posted November 25, 2020 Author Share Posted November 25, 2020 DONt know spigot. Quote Link to post Share on other sites
D6 Merv 1 Posted November 25, 2020 Share Posted November 25, 2020 8 minutes ago, rodhergott said: DONt know spigot. Spigot is the pto drive shaft hole where a winch goes. Doesn,t matter to you as ripper plate covers the hole. But there is still a bolt hole pattern around the outside of hole rippers bolt to Quote Link to post Share on other sites
mike newman 2,215 Posted November 25, 2020 Share Posted November 25, 2020 14 hours ago, D6 Merv said: Spigot is the pto drive shaft hole where a winch goes. Doesn,t matter to you as ripper plate covers the hole. But there is still a bolt hole pattern around the outside of hole rippers bolt to PM your ph # sometime , please Merv... Thanks Mike Quote Link to post Share on other sites
shot_gun_red 95 Posted December 4, 2020 Share Posted December 4, 2020 My 15c had a atco ripper and changed to a factory ih ripper . Sold it to a d6c cat guy and holes were off . He just used a mag drill. Quote Link to post Share on other sites
rodhergott 0 Posted December 4, 2020 Author Share Posted December 4, 2020 Thanks for the info. I think I will hold out for ripper from 15c Quote Link to post Share on other sites
farmalldr 108 Posted December 4, 2020 Share Posted December 4, 2020 I am fairly certain a TD15B or the 175 loaders have the same bolt pattern. Worth watching for and then measure for sure. Dennis Quote Link to post Share on other sites
rodhergott 0 Posted December 4, 2020 Author Share Posted December 4, 2020 Thanku for that help Quote Link to post Share on other sites
t4mike 2 Posted December 8, 2020 Share Posted December 8, 2020 i got this ih 1. it comes with this ih toolbar setup. https://i.postimg.cc/mrfvBjnF/SAM-2563.jpg Quote Link to post Share on other sites
rodhergott 0 Posted December 8, 2020 Author Share Posted December 8, 2020 1 minute ago, t4mike said: i got this ih 1. it comes with this ih toolbar setup. [url=https://postimages.org/][img]https://i.postimg.cc/mrfvBjnF/SAM-2563.jpg[/img][/url] To Quote Link to post Share on other sites
rodhergott 0 Posted December 8, 2020 Author Share Posted December 8, 2020 I can’t open Quote Link to post Share on other sites
