2 Bottom plows.
Mr. Plow
  • Replies 63
  • Created
  • Last Reply
16 hours ago, Mr. Plow said:
Rolling cutter template.
Nice!  I like it Steve, very cool.  Thank you for showing that set up.  I like what you're using for the template material, it will last you.  Only have to make it once then!
So you figure you will shut down the production line after this one?  What is your next project?
There MAY be a 3 bottom some day with 3 8" bottoms......or maybe a 4wd........
Early Riser Cyclo 800 (with cordless shopvac power)??????
Most likely will be to redo loader hydraulics.......
34 minutes ago, Mr. Plow said:
Sweet!
Ummm, if you make a planter....I WANT ONE!!!
I was daydreaming the other day about what other implements would look cool scaled down.  How about a ground driven side delivery rake ( for when the lawn gets outta hand!).?  Perhaps a rotary hoe for lawn aeration?
4 hours ago, nepoweshiekfarmalls said:
I was daydreaming the other day about what other implements would look cool scaled down.  How about a ground driven side delivery rake ( for when the lawn gets outta hand!).Perhaps a rotary hoe for lawn aeration?
I already use a section of rotary hoe for an aerator!?
I have a 2 section rotary hoe I do the same thing with!  I need a couple sets of wheel weights on a cub cadet to pull it on my hills.  Works well behind the 200.
  • 9 months later...
