Cattech 849 Posted November 11, 2020 Share Posted November 11, 2020 We installed new rotor tube covers in the 1460. Ended up having to get 16xx covers, so we had to add concave extensions, get the 16xx support and linkage etc. Installed a specialty rotor too. I haven't been able to find a setup procedure for the concaves and indicator. Right now, with the adjuster cranked up as tight as it will go and the stop bolts backed off, the closest the concaves get to a rasp is about 1". Quote Link to post Share on other sites
jass1660 1,940 Posted November 11, 2020 Share Posted November 11, 2020 The book gives the procedure. Zeroed out it should hit on certain bars on the concave if I’m remembering correctly. 1 Quote Link to post Share on other sites
J-Mech 1,157 Posted November 11, 2020 Share Posted November 11, 2020 48 minutes ago, jass1660 said: The book gives the procedure. Zeroed out it should hit on certain bars on the concave if I’m remembering correctly. Correct. Quote Link to post Share on other sites
Cattech 849 Posted November 11, 2020 Author Share Posted November 11, 2020 I see it now, not where I expected to find it. So, installed the 16xx extensions and the left side plate they bolt to, with the shorter linkages out of a 16 and we're not getting the travel to close the gap. As I mentioned, run all the way up produes about 1". Does the adjusting mechanism need to be replaced with 16xx stuff as well or do I have something else wrong yet. Quote Link to post Share on other sites
J-Mech 1,157 Posted November 12, 2020 Share Posted November 12, 2020 7 hours ago, Cattech said: I see it now, not where I expected to find it. So, installed the 16xx extensions and the left side plate they bolt to, with the shorter linkages out of a 16 and we're not getting the travel to close the gap. As I mentioned, run all the way up produes about 1". Does the adjusting mechanism need to be replaced with 16xx stuff as well or do I have something else wrong yet. Give us a picture. I'm not following your description. Quote Link to post Share on other sites
